Go Back   Home > Forums > Source & Line > Analog Line Level
Old 12th March 2012, 11:11 PM   #4421
gianc is offline gianc  Canada
I am using board from group buy Optical Volume Control Professional PCB
Is connection shown correct
Old 13th March 2012, 02:24 AM   #4422
georgehifi's Avatar
Send a message via MSN to georgehifi
No it is not, look and follow my diagram, the 5v constant goes to the wiper (center tap) yours is not the same.
File Type: jpg Lightspeed Attenuator MkII Circuit Dual Mono.JPG (44.9 KB, 264 views)
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 13th March 2012, 03:04 AM   #4423
BFNY is offline BFNY  United States
OK, interesting, the center wiper dual mono version. I saw that on someones site, but never tried it. Thanks for posting it.
Old 13th March 2012, 03:18 AM   #4424
This is much more confusing than just a doing stereo version.
So there is no way of using the single board in a dual mono configuration ?
I believe that is what BFNY was trying to explain to me previously.
Old 13th March 2012, 06:15 AM   #4425
georgehifi's Avatar
Yes you can but you'll have to look at it closely and cut some tracks. If you post the circuit board only up track side, I will nut it out for you and put on the 2 x single 100k log pots. And post it back up.
Cheers George
Old 13th March 2012, 08:08 AM   #4426
georgehifi's Avatar
Here it is done quicky, there are 5 cuts to make, and your calibration trimpots are still in the circuit should you need them, if the ldr's are properly quad matched you should bridge them out now that you have L&R volume controls. Like I said I did this quickly so shoot me if there are any mistakes.
Cheers George
Old 13th March 2012, 01:56 PM   #4427
Many thanks George.
I will post a pic of actual board showing trace side and connections as per your diagram.
Old 13th March 2012, 08:20 PM   #4428
georgehifi's Avatar
What I have posted in post 4426 is it, follow it do the cuts and all should be right.
Cheers George
Old 13th March 2012, 08:35 PM   #4429
georgehifi's Avatar
Just in case, here is the same but with the tracks bent around the series resistor, just in case you may have thought they were soldered to them as well.
Cheers George
Old 14th March 2012, 04:16 AM   #4430
Thanks again George. Aussies rule !!
I will go ahead and order the mono pots, and post results.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
