Lightspeed Attenuator a new passive preamp - Page 441 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 15th February 2012, 05:56 PM   #4401
djn is offline djn  United States
djn's Avatar
Originally Posted by merlin2069er View Post
I've looked at that one Merlin. Although I can't make sense out of how to implement it. If the pot on the lightspeed just supplies 5v, then all the "stuff" on that board would be for naut. However, there is a really good chance that I am missing something.
What I "think" I need is just a pot with a motor on the back and some form of remote control.
Old 15th February 2012, 06:25 PM   #4402
Marra is offline Marra  United Kingdom
Why not check out Maximus VCCS version.Balance facility too.
Old 15th February 2012, 08:31 PM   #4403
georgehifi's Avatar
Send a message via MSN to georgehifi
Originally Posted by djn View Post
I've looked at that one Merlin. Although I can't make sense out of how to implement it. If the pot on the lightspeed just supplies 5v, then all the "stuff" on that board would be for naut. .
A few of my customers who are lounge lizards have used this RC volume control that I put them onto, you do need all that's there, as it is the power and receiver circuit for the remote the power and driver for the motorized pot, and the relay input switching circuit. The only thing you need to do is to do a bit of surgery to the input/output tracks of the volume control to make it the same as the Lightspeed Attenuator (attached). Also it is not from what I've been told a genuine Alps pot and it is very course in it's action and they seem to think the remote will not last too many years.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 15th February 2012, 08:44 PM   #4404
AndrewT is online now AndrewT  Scotland
The carbon film tracks are etched/lazered on a single blank.
The common between input and output is indeed common for both channels.
I don't have the skills necessary to cut the track at common and reattach the lead out wiper, to create two separate tracks.
If you have some other pot that can be hung on the end of the motor then it may be possible to convert this MV02 kit into the driver pot for a Lightspeed.
I do have the pot and gearing mechanism open to take a pic or ten, if you think that modifying the pot is possible.
The operating software in the controller is a bit odd.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd February 2012, 09:02 PM   #4405
djn's Avatar
I emailed Pete Millette today to see how much the input impedance is on the Low Mu preamp and he said it is high and matches well with the light speed. So now my next question is: How much difference is there between the lightspeed and lighter note?
Old 23rd February 2012, 09:07 PM   #4406
udailey is offline udailey  United States
You can email me and ask. I dont want to put things like that on George's thread. This thread is specifically about the Lightspeed.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 23rd February 2012, 09:12 PM   #4407
djn's Avatar
Understood.
Old 23rd February 2012, 11:08 PM   #4408
BFNY is offline BFNY  United States
If you are into keeping it simple, you can buy a motorized dual gang Alps pot from Mouser and other sources, (under $20) and then wire it to a remote control box - i.e. wired remote control. Bent Audio also sells raw remote control kits, probably higher quality/better support, (but for more $) than Chinese stuff on Ebay.
http://www.bentaudio.com/index2.html
http://www.bentaudio.com/DLFILES/REM-ALPS-R1.pdf
Looking at the manual, this one also needs the traces cut into/out of the pot cut and then wired manually. Also note it is 50K, not 100K.
Old 24th February 2012, 12:39 AM   #4409
georgehifi's Avatar
With the Lightspeed Attenuator a 100k dual log will give a nice logarithmic feel to the progression of the volume (gradual from min to 2 o'clock then accelerating to the max). A 50kohm will be very sudden (too quick) down low and not very nice to use.
Cheers George
Old 24th February 2012, 01:37 PM   #4410
djn's Avatar
Will the feel get better with a 250k pot? My chassis needs to gear the volume pot 2:1 so the volume lever will travel 1/2 the distance as the volume pot. That will really make for sudden jumps in volume.
Copyright 1999-2017 diyAudio
