| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#4291 | |
#4292 |
Just put a DMM set at high Z, across the cell only, (no need to power the led), and you will get a stable Z reading, then hold the body with just your fingers and you will see the Z change quite a bit.
This is why I have always said to have all 4 units together and then pot them in hard snow ski base wax. And you can use one of these for matching your LDR's Cheers George Last edited by georgehifi; 5th November 2011 at 09:52 PM. |
#4293 |
Passive Aggressive
I use a voltage regulator into a current source into yet another current source with smoothing capacitors left and right and it sounds fantastic. If you blow on the LDR it changes resistance still.
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#4294 |
Passive Aggressive
What George does is probably the best solution there. I dont do it because it doesnt bother me, but if I was worried then I would try to get them in wax or hot glue.
#4295 | |
Passive Aggressive
#4296 |
#4297 |
Now you know why I strongly advise against putting the Lightspeed inside an amp, and to pot them in hard wax as well.
Cheers George |
#4298 |
A friend of mine built an attenuator based on LDR design. I noticed that L+R channels are imbalanced. when the pot knob is turned up, it starts from R channel +5dBFS louder then L channel (minimum), but when knob turning up, the imbalance gets smaller and smaller, until around -20dbFS (around middle) it's almost perfect, then Left channel (when turning up) became louder and louder - up to -5dBFs, and it's almost perfect when in full 'open' position. I was told it is just a problem with LDR and it possibly can't be resolved, but I remember reading some audio purist using LDR att. and I don't think they wouldn't notice a 5dB difference between channels, so I presume it's possibly to have it ideal (0.1dB - I can live with, 0.2dB - would be maximum) Could you please help me - what could cause this sort of problem ? How to resolve it ? Is it simply swapping a pair of LDRs or sth else ? I really appreciate your help, here - thank you in advance If LDR design is not perfect and it's very difficult to find pair of LDR with 0.1dB difference - could you please advise me, what type of passive att. would be good ? - in a 'human - 99%' price range |
#4299 |
Buy matched pairs of LDRs or buy the real "Lightspeed" attenuator.
If you read this thread you will see all explained in detail of the why and how. |
#4300 | |
I am thinking about either giving up on this project or using other option (ALPS pot), I am not a real diy'er, so please explain; thank you |
