Lightspeed Attenuator a new passive preamp - Page 410 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 14th May 2011, 01:08 PM   #4091
It's an almost impossible task to read 409 pages here to find something.
Can someone tell me on what pages I may find the ccs controlled version for LDR attenuators?
Old 14th May 2011, 11:07 PM   #4092
georgehifi's Avatar
Send a message via MSN to georgehifi
Look search for maximus (Paul Hynes) posts I think he's doing one.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 15th May 2011, 05:30 AM   #4093
Hi bp,
There is a version that does drive low impedance loads built by "Blues" [WarpSpeed"] - It's quite happy driving my F3 with it's input impedance of 9kR and I understand it is okay down to about 3kR - the "normal" versions (George's & Uriah's) do require a buffer, and/or gain stage.
Old 15th May 2011, 02:45 PM   #4094
My concern is that my power amp's impedance, as many out there, is around 20K. Wouldn't I need a buffer?
About the input impedance, am I missing something is is it fine to feed low impedance sources into it?
Old 15th May 2011, 06:54 PM   #4095
Originally Posted by carlmart View Post
. . . my power amp's impedance, as many out there, is around 20K. Wouldn't I need a buffer?
I drive a Quad303 (input impedance = 20K) with a Lightspeed with no apparent issues. My advice would be just to try it.
HTH
Dave
Old 15th May 2011, 08:48 PM   #4096
With no buffer?
OK. Good advice. I was going to do that anyway, but I saw Nelson Pass LDR + preamp, and it needed several things I can't find here, like more matched LDRs and matched SJ170/SJ74.
If I was going to provide a buffer, then I would have to get the parts.
Old 15th May 2011, 09:32 PM   #4097
With no buffer?
With no buffer.
Of course, I've no idea how it would sound if I had a buffer - but I don't. And it sounds pretty good to me.
Old 16th May 2011, 09:29 PM   #4098
udailey is offline udailey  United States
Nowadays I drive a 10k amp with mine. Just took it to a show and did not have a problem. Got many great comments and am working with a dealer who says its the best pre he has ever heard. I have used a buffer though and have posted my impressions in this thread in the last year or so.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 16th May 2011, 09:36 PM   #4099
ua100k is offline ua100k  United States
ua100k's Avatar
I use the Warpspeed without a buffer on multiple set ups with no problems. However I cannot say what the impedances were for all of them. I did use it tube and solid state without buffers.
It is cheap enough to try a few of them if you can. Warpspeed and DIY Paradise Eva II comes as a completed unit if you prefer not to get your hands dirty. Myth, The Truth are a little more costly as finished units.
Old 16th May 2011, 09:39 PM   #4100
sepolansky's Avatar
The only thing important is the output impedance of the source, in this matter. Keep it under a couple hundred ohms as George pointed out (years ago?) and you'll be fine.
Copyright 1999-2017 diyAudio
