Go Back   Home > Forums > Source & Line > Analog Line Level
Old 22nd January 2011, 06:57 PM   #3931
udailey is offline udailey  United States
Passive Aggressive
It is expensive and the 2sj74 and 2sk170 are a guarantee. I dont blame you. Glad you are enjoying George's creation and happy I could help.
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 23rd January 2011, 10:19 PM   #3932
georgehifi's Avatar
Send a message via MSN to georgehifi
Here's an interesting snippet from the latest Stereophile review of the DCS Debussy Dac which has volume control in the digital domain. Yet two stage adjustable analogue level output stage 2v or 6v, this means you can use it straight into a poweramp and only use the top 25% of the digital volume control, this way you should not be "bit striping".
Sterophile Quote: The differences in sound between the Debussy into a preamplifier and the Debussy directly driving a power amplifier will depend on the preamp's transparency, dynamic capabilities, and overall quality. Sending signals directly to my Musical Fidelity Titan amp from the Debussy or through my reference preamp, a darTZeel NHB-18NS, I heard minimal differences. Given the darTZeel's price of $29,500, that's what you should expect. :Stereophile Quote
Guess what the Dartzeel uses as a volume control? you guessed it. A Lightspeed setup, they tried to patent when they first released it but I quickly put a stop to it showing proof to the patent offices in Eu and USA that I first did the LDR volume control back in early 1974.
Quote from the Stereophile Review of the darTZeel NHB-18NS
"For the first time in all audio history," said Delétraz, "the signal path does not pass through any physical switch, relay, or even transistor switch." Instead, inputs are enabled or disabled using electro-optical analog components. Because there is no physical input switch or FET-based analog switch, there is no "diode effect," either electrical or chemical (electrovalence differential), to alter the signal, he explained in an e-mail. Quote
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 27th January 2011, 09:55 PM   #3933
ua100k is offline ua100k  United States
ua100k's Avatar
George,
Curious, how did you know they were about to patent this idea. Great that you caught it!!
Old 28th January 2011, 03:11 AM   #3934
georgehifi's Avatar
In the 6 Moons review. The interview with Herve is after the review of the NHB-18NS.
6moons audio reviews: darTZeel NHB-18NS
Q: What is wrong with conventional volume controls?
A: You lose something. I use a system that varies resistance with light. However, until all the patents are in place, I would prefer not to specify the details.
Cheers George
Old 28th January 2011, 11:39 AM   #3935
ua100k's Avatar
Great catch. Thank you for doing that and taking care of the community. I see they do not use that statement on they web site now.
Old 28th January 2011, 06:51 PM   #3936
I see that the $23,500 darTZeel NHB-18NS has "a Pleasure control" and an "Enjoyment Source". Is it an amplifier or an upmarket sex toy?
My little Lightspeed is starting to look a bit dull. Can I call it an "Optical Relief"?
Old 28th January 2011, 08:18 PM   #3937
sepolansky's Avatar
Is the darTZeel push-pull?
Old 28th January 2011, 08:37 PM   #3938
....and does it suffer midrange suck out ?
Old 29th January 2011, 06:33 PM   #3939
I have a quick newbie question. On the 100k volume control dual potentiometer, what is the purpose of shorting pin 2 and 3 on one gang and pin 1 and 2 on the other gang? Can we just use the pin 2 on both gang, and leave pin 3 and pin 1 alone?
Old 29th January 2011, 10:11 PM   #3940
Just finished building the Lightspeed kit I bought from udailey. Good news is it works! However the volume control is reversed somehow. The volume goes down when turned clockwise, and goes up when turned counter clockwise. Can I simply swap the leads going to main LDR and shunt LDR from the potentiometer?
Copyright ©1999-2013 diyAudio
