Lightspeed Attenuator a new passive preamp - Page 345 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 30th July 2010, 02:01 PM   #3441
udailey is offline udailey  United States
Yeah, ignore what I said. I saw the diodes and ignored them, not realizing they were the LED side of the LDR.
Looks like a fun circuit but also looks like the post from 1360 is more obvious how to operate it than the one posted a few posts back as with the latest post we dont see how to individually manipulate the LDRs.
Do you see how to manipulate the channels individually as in post 1360? I think R3 and R4, if they were trimmers would help you.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 30th July 2010, 03:33 PM   #3442
Uriah,
Nelson's design only attenuates about 35dB attenuation, unlike your "full range" units, and the buffer here isn't out familiar B1, but the complementary k170/j74 one - apart from that and the higher impedance range of the S3 ldes, it works in the same way, so operating them in parallel with variations of the 431 current distribution (ie balance trim) shouldn't present any problems.
Zum, for that imbalance, assuming matched devices, just measure the voltages at the led ends and if they're the same, check for a bodgie resistor, especially the pot.
Old 30th July 2010, 10:25 PM   #3443
georgehifi's Avatar
Send a message via MSN to georgehifi
And this one.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 30th July 2010, 11:01 PM   #3444
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
hey George, where did you find that one ?
sometimes we know very little, and sometimes we know too much
Old 31st July 2010, 12:56 AM   #3445
ZUM911 is offline ZUM911  Australia
Thanks all for the help. I matched the ldr's as best as I could from the batch I had. As they are wired in series, I can't figure how to trim them individually. I suppose I could swap the ldr's around to find a better balance but wanted to avoid heating them too much. The imbalance is not too bad, about 7 percent measured difference, and on some music not noticeable so I might just learn to live with it.
Cheers
Rick
Old 31st July 2010, 12:59 AM   #3446
georgehifi's Avatar
Can't remember tinitus, in was in my files maybe Nelson sent it to me?
Being 1K ouput is still too high in my opinion for low input impedance amps, but at least it's direct coupled, I hate the sound of even the best coupling caps.
Cheers George
Old 31st July 2010, 01:02 AM   #3447
Rick,
If you get a chance could you shoot us some pictures?
Uriah
Old 31st July 2010, 01:34 AM   #3448
Blues is offline Blues  United States
Blues's Avatar
Cheers George
Deep in the thread you'll see NP posted variations on the LDR design as an attenuator...the attached (post# 3443) is a re-drawing of his design for a better (IMHO) understanding...so is the "much improved" schematics of the Lightspeed that George uses to post every now and then...even a half-hearted credit for the little help will be nice
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 31st July 2010, 02:02 AM   #3449
Uriah,
Here's some images. A bit of rat's nest but it works. I originally had the buffer on the output but have changed to the input to use with my CD player that has a higher Zo. Both ways I had the same imbalance.
Cheers
Rick
Old 31st July 2010, 03:51 AM   #3450
Might look like a rats nest but I bet it sounds good Reminds me of my perfboard F5.
Copyright 1999-2017 diyAudio
