| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#3421 |
Passive Aggressive
Hi Richard. Can you post a pic or send one to me of your set up? I wonder if you have one of two possible problems
1: Put shunt LDRs in series spot 2: Wired 5k pot in wrong. Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#3422 |
Passive Aggressive
I dont think the calibration of shunt has anything to do with it at all. As soon as you turn the volume up a little bit that 200R trimmer stops having any effect on centering the image as it becomes a minor percentage of your position on the 100k pot.
Uriah
#3423 |
Passive Aggressive
When I say series in shunt spot basically what I mean is this
We have across the board 4 LDRs. Lets call them ABCD and they are in that order. A is shunt, B is series, C is shunt, D is series. So if we took a pair out of the bag and put them in the board the proper way would be that the pair would either go in A and C or in B and D but NOT AB or CD. Uriah
#3424 |
#3425 |
Passive Aggressive
Richard, Have you seen this?
https://docs.google.com/fileview?id=...OTNjMzdm&hl=en
#3426 | |
#3427 | |
#3428 |
Passive Aggressive
Okay, from the top it looks fine. Thank you for the pics.
I would look to your balance pot and see if it is wired correctly. The Wiper should be the middle hole in the 'series balance' spot. If you switch the outer wires from the 5k pot around then the balance will work in the opposite direction. Uriah
#3429 | |
#3430 |
Passive Aggressive
Richard, When I search for "richard's" who have bought from me there is only one so I am assuming its you. You have built a few of these. I trust you have done everything correctly and maybe I am the one who made a mistake. If you send it back to me I will test it and either fix it or send you a new kit.
Uriah
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Page generated in 0.10519 seconds (66.22% PHP - 33.78% MySQL) with 11 queries |
