Lightspeed Attenuator a new passive preamp - Page 285 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 23rd December 2009, 07:59 PM   #2841
Tripmaster's Avatar
Originally Posted by AndrewT View Post
what is the voltage with the circuit disconnected, i.e. no LED and no LDRs.
When I applied power it peaked at 15v and after 30 seconds the voltage settled at 14.92v
Old 23rd December 2009, 08:55 PM   #2842
Puffin is offline Puffin  United Kingdom
Tripmaster and I discussed this problem. We wondered whether it could be reverse voltage. Would a diode on the 7805 be worth doing in any event?
Old 23rd December 2009, 09:19 PM   #2843
Tripmaster's Avatar
Yes. Ive just added a diode to the LED
Old 23rd December 2009, 09:22 PM   #2844
Does that do the same thing as across the 7805?
Old 23rd December 2009, 10:53 PM   #2845
Tripmaster's Avatar
No
Old 24th December 2009, 08:25 AM   #2846
Old 24th December 2009, 12:34 PM   #2847
15V at the smoothing cap with no load.
drops to 14.45V with the LDRs drawing current.
drops to 13.87V with the single LED added.
You need proper smoothing cap across the rectified supply.
Try 1000uF or somewhere close, 470uF to 2200uF.
Measure those three conditions again.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th December 2009, 12:50 PM   #2848
Tripmaster's Avatar
Hi Andrew
I'm keeping you busy!
Should I place this cap before the regulator, just after the green terminal block?
Old 24th December 2009, 01:09 PM   #2849
yes, locate the smoothing right after the power input terminals.
regards Andrew T.
Old 24th December 2009, 01:25 PM   #2850
I use 1,000uf either side of the reg.
[IMG][img=http://img15.imageshack.us/img15/686/daveslspeednd008.th.jpg][/IMG]
Copyright 1999-2017 diyAudio
