Go Back   Home > Forums > Source & Line > Analog Line Level
Old 21st September 2006, 01:39 AM   #221
Default Group Buy
I think if you guys get together and order from RS you will be very happy. My sorted LDR's are all over the place, both in slope and offset. There were matched at three current levels.
The exponetial slope needed for atttenuation makes matching much less critical than you might expect. I checked some stereo pots and was shocked at how poorly they tracked. Some were 50% at middle range, and these were expensive conductive plastic.
My recommendation is two use two control stereo pots, and not the trimmer circuit. This way a small imbalance is easily corrected. I use the two controls when chasing problems from all the diy and modified gear in my system. Sometimes there are lots of gremlins.
I keep wanting to add a buffer after the Lightspeed clone. Thinking of a simple jfet or BJT with degeneration. But am completely happy with the sound as it is.
George
Old 21st September 2006, 04:06 AM   #222
EUVL is offline EUVL  Europe
There are a number of possible sources in Europe, of which Banzai is one. RS (UK) has the best price so far. But if no one in the UK is volunteering, there would be no group buy. As mentioned, I already got 25 SR3s from RS Germany, so I have no urgent need.
George put it very well, the advantage of the Group Buy is not only a bit of saving, but more importantly the better match.
Patrick
Old 22nd September 2006, 10:09 PM   #223
a333bt is offline a333bt  Slovenia
i am also interested in group buy.
regards, Bostjan
Old 25th September 2006, 09:50 PM   #224
JoshK is offline JoshK  United States
This seems to be an ideal way to do a multichannel attenuator with only a stereo pot. You just have to match as many LDRs as you have channels (not sure how hard that will be).
I really want to give this a try my my multiamped system. I already have a motorised remote controlled 100K pot. Is there a more clever way to do balanced channels then a shunt for each leg?
Old 25th September 2006, 10:29 PM   #225
YES! Imagine a shunt regulator: a series resistor and a adjustable shunting resistor to ground. Now imagine two of those, one for + and one for -. Now, instead of connecting the shunt resistors to ground, connect both ends to each other, so that there is no connection to gnd anymore. Now you can change the two independent shunt resistors for one!
I know, I picture says a thousand words, but I don't have one on hand right now.
Erik
Old 26th September 2006, 05:03 AM   #226
blu_line's Avatar
I am in for a grup buy !
Currently i am,also , building a multichannel amp and need to tackle the volume control section as previous posters mentioned.
6-10 will do fine !
grtz
Simon
Old 26th September 2006, 01:31 PM   #227
Erik
So if I understand you correctly you are putting a "T" between the legs? Voltage dividing between the two legs and then shunting that to ground. This would require 3 LDRs if I understand this correctly? One in series with each leg and one from the voltage dividing node to ground.
Old 26th September 2006, 02:04 PM   #228
Hi JoshK
Here is a picture (post 10), worth a thousand from my confusing english words.
How to connect a pot balanced
You see that you will need just one LDR per channel + 2 high precision resistors.
Erik
Old 26th September 2006, 05:37 PM   #229
> Nelson Pass : I don't trust those figures, and I would have to run them myself for these parts, as I am unaware of any big advances in Cadmium Sulfide cells. My examples had large distortion at ordinary line levels.
According to information from both Silonex and Perkin Elmer, the amount of distortion depends greatly on material type as well as voltage rating / level. There are types from Silonex with much higher distortions.
But I have no data to support or disclaim the Silonex data. The LDRs are there, just no time to measure as yet. I am also not for or against LDRs, but I am most curious to find out.
Patrick
Old 1st October 2006, 11:55 PM   #230
wineds is offline wineds  Australia
Here is a link to local preamp shootout including a lightspeed clone for those who might be interested http://www.dtvforum.info/index.php?s...ic=36129&st=80
I have no relationship with George, I only corresponded with him for the first time yesterday.
The Lightspeed clone was up against some very well regarded pres and did very well.
Paul
PS: Starts at about post 88
Page generated in 0.12530 seconds (55.70% PHP - 44.30% MySQL) with 11 queries
