| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#1121 |
Thanks George
If my friends from Australia which plan to visit me order attenuator from You could You tell me about delivery time regards |
#1122 | |
majkisk, I will have two in stock for immediate delivery in 2 days, one can be sent to Macedonia insured/air post for $50aud (30euro) or I can send it to your friends here in Australia. Contact me with (PM below) with your email address and I will send some literature on the Lightspeed Attenuator to you. http://www.diyaudio.com/forums/membe...rm&userid=8370 or you can just email me at ( georgehifiatoptusnet.com.au ) substitute the at for @ Cheers George |
#1123 |
Passive Pre Amp forum? Yes please.
Vote here for it, if you haven't already. http://www.diyaudio.com/request/ Cheers George |
#1124 |
pietjer,
Can your CCS circuit be powered off of a 12v wallwort, or is a "cleaner" source recommended? |
#1125 |
Staggerlee,
The CCS is giving a very high rejection of mains related pollution, so a standard stabilized (!) 12V mains adapter is okay. The voltage of the power supply is not very critical. Every voltage between lets say 8V and 20V is okay. Peter |
#1126 |
If used on a balanced headphone amp,is the series opto on "hot" and the shunt to "cold" then?
Regards Åke |
#1127 | |
Two series in hot & cold then after these two shunts from hot & cold to ground. For pseudo balanced you could try having the same two series resistors but only one shunt - between hot & cold. |
#1128 | |
Regards Åke |
#1129 |
If you use the CCS cct then you can put the 4 opto couplers in series.
should be ok I think 12 volts will still be enough but 15 volts would also work |
#1130 |
Knowing that some of you are building (or planning to build) the CCS version of the Lightspeed, I am very interested to hear from your results.
Please share your findings and thoughts. Peter |
| Page generated in 0.13507 seconds (70.46% PHP - 29.54% MySQL) with 11 queries |
