Op-amp help! What is 6552?!?!?! - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 16th May 2006, 07:42 PM   #1
Default Op-amp help! What is 6552?!?!?!
In the tuner I'm going to tweak: a technics St-S1 there's an ic : it has 8 pins, in dual in line pacKage... on the top is written 6552, is it an op-amp? Could be something else? Do you think I can replace it with an audiophile one? The tuner comes witha transistor output stage before an ic that protect against pop... I don't know if the ic is in the tuner section and if i can replace it obviously if it is an op-amp....
Any idea?
Thank You all....!
Domenico
Old 16th May 2006, 08:05 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Domenico,
Your opamp is most likely the AN6552. Datasheet can easily be found on the net using Google.
I'll refrain from other comments because I don't know the tuner.
/Hugo
Old 16th May 2006, 08:44 PM   #3
Most of all I'mn intersted to know if this little ic could be somthing else in this package, since in the top isn't write "an", obviously it's a Technics (trhat means panasonic so is could be esxtremely probable this is this component...
Thank you,
Domenico
PS If You have any suggestion to improve the tuner please make me know!
Old 16th May 2006, 09:01 PM   #4
Netlist's Avatar
You will need a schematic if you want to do some tweaks and confirm that the IC is indeed the AN6552. All other assumptions is like working in the dark. I'll check my pile of old schematics tomorrow.
/Hugo
Old 16th May 2006, 09:37 PM   #5
johnnyx is offline johnnyx  United Kingdom
A link to the AN6552 datasheet Here
Old 17th May 2006, 07:51 AM   #6
Thanks for the op-amp datasheet link...
I have asked many on line schematic seller for the st-s1, thay have in catalogue the ST-S1 schematic but when I asked them for a copy no reply has been send...( excuse my horrible english)
If you find a schematic copy and you can send me a scan of it, It will be so helpfull!
Bye,
Do
Old 18th May 2006, 06:40 AM   #7
earsandeyes's Avatar
Have you asked Technics service people for the schematic. When it is out of production for some time sometimes they just mail you one. That happened to me at least in search for a JVC tuner.
regards,
e&e
Old 18th May 2006, 07:03 AM   #8
Netlist's Avatar
I don't have the ST-S1 schematic. From what I've seen in other Technics tuners, the AN6552 is used as the output driver; line and headphones.
/Hugo
Old 18th May 2006, 12:15 PM   #9
This op amp should be a NE5532 clone!
ciao cicero32
Copyright 1999-2017 diyAudio
