Mint Tin Phono Amplifier
Old 9th October 2006, 01:43 AM   #21
ALBQ is offline ALBQ  United States
Default Plot thickens
Bob,
Sounds like you are in real trouble. Please private email me and I will help with a solution. Without a board in front of me, hard to tell whats going on. Also, please post that you hit my private mail from the board - I don't normally check it.
Cheers - ALBQ
Old 9th October 2006, 02:01 PM   #22
Smokehouse Bob is offline Smokehouse Bob  United States
Smokehouse Bob's Avatar
E-mail attempted but rejected by the board. Not sure how best to remedy that. Thanks again!
Old 10th October 2006, 12:13 AM   #23
I'll buy one off eBay instead.
Old 10th October 2006, 12:21 AM   #24
Default Mint Tin Phono
Bob,
Here is the link to my Webpage. Private email me with contact info and I will send you the prototype - the amp pictured on the original post.
Cheers - ALBQ
http://mywebpages.comcast.net/gilles...-MainPage.html
Old 10th October 2006, 12:45 AM   #25
Done Chief! And not a moment too soon as I was about to BIN. Thanks!
Old 10th October 2006, 01:15 AM   #26
Default You have mail
Bob,
Check your private email - talk to you soon
Cheers -ALBQ
Old 11th October 2006, 12:21 AM   #27
I jumpered the R5 rather insertng the resistor. Okie dokie. Rewired on a new board and I've got sound, just no amplification. Same volume with or without the battery. Voltages measure 4.15 +/- on the pin 4 and 8 of the socket. Well, at least it hasn't gotten hot or melted!! Maybe I had a bad cap (although new) or the new IC is crap.
Old 11th October 2006, 02:04 AM   #28
Default Resistor
Bob,
Sorry for being dense. From the posted schematic, which resistor did you jumper?
Thank you -ALBQ
Old 11th October 2006, 11:37 AM   #29
Hi ya ALBQ,
I jumpered at both R5 locations, left and right, under the R4 location. If I connect my source inputs to the "bent M-shaped" jumpers on the left and right, I get full volume from the source, but no amplification whether the the battery is connected or not. However, if I connect the source inputs (left and right) to the locations noted by Tangent, I get silence. I'm seriously missing something and I just don't see it yet.
I changed to other new caps (still 0.1 uF since bigger won't fit easily), refitted jumpers on a new board, cleaned flux using 91% alcohol, and rechecked my resistors. All measure out as expected.
Thinking that I might have goofed on the input jacks, I checked input and output connections on my alligator clips for left, right, and ground. Again, all is good.
Somewhere out there is an amplified signal just waiting to be heard, I must find it. Frustrated, yes. Discouraged, no. Thanks ALBQ. These little devices can't be that hard to assemble, can they?
Smokehouse Bob
Old 12th October 2006, 11:14 AM   #30
Bob,
For what its worth, I have made several versions of the CMoy headphone amp on perf pcb and always struggle. Although I can get the things to work, space is tight and I find it difficult to make sure all of the connections are correct. This circuit has even more parts in the feedback loop (riaa filter) so, more difficult still. That is why I made a pcb. Mush easier to get right and still keep the overall footprint down. Do you know how to use or have access to a scope? Makes troubleshooting analog signals musch easier. Sorry cannot be of more help -ALBQ
Mint Tin Phono AmplifierHide this!Advertise here!
FS: Crown D-75A Amplifier - MINT! chops Swap Meet 13 21st March 2008 12:18 AM
2 x TC2+ 15" subwoofers for sale (possibly 4) and mint Crown K2 amplifier taloyd Swap Meet 6 4th May 2007 03:30 PM
FS: Yamamoto A08-S tube amplifier, mint condition AD Swap Meet 2 26th January 2007 04:07 PM
Musical Fidelity A3cr Power Amplifier - mint - relisted EDDIEMUNSTER Swap Meet 0 10th January 2007 02:53 AM
Phono Pre Amplifier Schematics marlow Solid State 2 13th December 2001 11:15 PM
