wanted quickly!!!! a circuit to convert mono to stereo.
Old 23rd April 2006, 09:16 AM   #1
sagarverma is offline sagarverma  India
sagarverma's Avatar
Default wanted quickly!!!! a circuit to convert mono to stereo.
i need a circut (a simple one ) to convert the single wire output to double wire.
i.e i have audio out as : one live wire and one gnd.....i want it to be like two live wires and a ground.
power is line level and NOT power amplifier one.
quick help required
SAGAR
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum
Old 23rd April 2006, 09:38 AM   #2
Nigel Goodwin is offline Nigel Goodwin  England
Default Re: wanted quickly!!!! a circuit to convert mono to stereo.
quick help required
SAGAR
Just join both channel inputs together, it won't be stereo, just dual channel mono - but you can't produce stereo from a mono signal.
Nigel Goodwin
Old 23rd April 2006, 09:48 AM   #3
sagarverma's Avatar
thanks for the reply.
i m not at all interested in stereo output,what i want to do is to convert the 2 wire system into a 3 wire system.
what i did is to take two 10k res,connected end to end and the common end being fed with the mono signal.and the other two ends going into the tda ic which have caps at there i/p.it forms a RC network that i suspect can interfere with the music reproduction.
i have a mono line level source that is to be fed into a tda1554q chip amp.so what should i do(tda ic is wired for 2*22 w config.)
Sagar
Old 23rd April 2006, 09:59 AM   #4
You're over complicating it! - just join the wires together, no need for resistors or anything - you're simply connecting one output to two inputs, it's no different to connecting a pair of speakers in parallel (except no impedance worries).
The resistor solution should be fine as well, but not required at all. If you were feeding two OUTPUTS to one INPUT, then the simple resistive mixer would be needed, and is a standard crude solution.
Nigel Goodwin
Old 10th May 2006, 11:06 AM   #5
sagarverma's Avatar
Thanks Nigel for the timely help.
i did precisely what u said and it worked fine.served my purpose.
thanks was overdue i m givin it 2 u as soon as i got time.
wanted quickly!!!! a circuit to convert mono to stereo.Hide this!Advertise here!
Convert Stereo Headshell To MONO MZ Analogue Source 0 6th February 2008 07:24 PM
stereo to mono network/circuit wesley530 Car Audio 2 5th December 2007 11:52 PM
How to convert S5 K-12g kit to dual mono? downward_dog Tubes / Valves 4 11th January 2007 12:57 PM
Mono DAC using sample/hold circuit for stereo mr_push_pull Digital Source 0 29th September 2006 07:35 PM
Building a phase inverter to convert stereo to mono Clarkcr Solid State 3 22nd June 2004 08:28 PM
Copyright ©1999-2017 diyAudio
