What's the function of this?
2 Attachment(s)
Hi Folk!
I'm analysing a circuit from a pre-amplifier. I don't have the schematics. Not all component are represented on this home made diagram. Does someone understand the use of IC400 in this circuit? Thanks for your help. |
It's an integrator that is performing the task of DC servo and holding the DC at the output of the second IC at 0V. Quite why they've chosen to use an OPA2134 for that function, I don't understand. The servo op-amp is usually chosen for its low DC offset rather than good audio quality.
Great thanks. I was thinking too for a DC servo but I was confused as they use an 2114 for the "audio signal" and an 2134 for the DC...
Do you will have a recommandation to update both opamp? I was thinking to an AD8620B for the IC400 and 2134 (or something else) for IC403. . |
What about AD822 for IC400?
| All times are GMT. The time now is 02:03 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
