Go Back   Home > Forums > Source & Line > Analog Line Level
Old 22nd March 2006, 05:08 PM   #11
Lyra is offline Lyra  Norway
Lyra's Avatar
Originally posted by davidsrsb
It would not have been an Elektor design without an oddball device like that SSM2142.
The SSM2142 is not part of the "original" Elektor design...it is a balanced line driver I've implemented with "my version" of the Westhost design...
Lyra
Old 22nd March 2006, 09:18 PM   #12
moamps is offline moamps  Croatia
The Elektor circuit has an even longer sequence so it should be OK. It uses more common devices so it may be easier to build.
I don't know if the pinking filter is correct.
Hi:
The sequence is 2^31-1. -3dB/oct filter accuracy is very good and better than that published on the Elliot's site.
Milan
Old 22nd March 2006, 09:30 PM   #13
Lyra's Avatar
Originally posted by moamps
Hi:
Milan
This was good news...
Think I'll have to see if I can use this one then...but not this night...
Lyra
Does Pink noise follow the V x V/R method? OMNIFEX Solid State 18 5th January 2009 03:46 PM
What does pink noise sound like? jamikl Multi-Way 23 31st July 2008 02:23 AM
Pink Noise .wav generator MisterTwister Everything Else 10 30th April 2007 05:10 PM
software 1/3 octave pink noise generator deandob Multi-Way 6 25th March 2006 06:05 AM
Digital Pink Noise generator...? Lyra Digital Source 12 22nd March 2006 02:06 AM
Page generated in 0.07657 seconds (81.04% PHP - 18.96% MySQL) with 11 queries
