| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
hi i need an analog adjustable time deay in the range off 20-500 microseconds.
can anybody point a schematic? thank you |
#2 |
Over what frequency range? Most analog delays are only good over a certain frequency range
IE: If we had a circuit with an analog delay of 1usec over 20Hz - 20kHz, and we used it outside of that range (let's say 30kHz), the delay would not be 1usec anymore (could be more or less). Another issue is that analog delays usually have amplitude gain nonlinearity over frequency (in our previous example, the voltage gain at 20Hz is probably not the same as the voltage gain at 20kHz). ==> Are you sure you can't digitize your source and use a digital delay? I would think that a digital delay would probably be MUCH more accurate and precise. |
#3 |
i didn`t know that.
i want to use it to the output of a crossover. the frequency ranges are 300-5000 for the mid and 5000 -20000 for the tweeter. i don`t want to digitize it again. i was looking for a way to improve quality easily. if it can`t be done i will wait to get a digital xover. |
#4 |
an all pass filter will give you a time delay. Do a search on filters and on all pass and you should find many. I would expect most could be made adjustable, but you would need to change at least 2 poles so a switched adjuster may be necessary rather than a ganged pot.
regards Andrew T. |
#5 |
If you want to achieve a constant group delay over a large (but still restricted) frequency range you will need a very high-order allpass.
Regards Charles |
#6 |
#7 |
thank you all for your help.
i don`t want to aplly phase correction only but real time delay over the entire range of each driver. i guess that is called group dealy? i think that the linkwitz link is all i need i will study it when i have more time. |
#8 |
I think that time delay equals phase correction in these allpass filters.
regards Andrew T. |
#9 |
Why not just align the drivers? At most, you need 20cm difference.
#10 |
One trick you can use to let you get away with less allpass stages is to delay the mid and invert its signal relative to the tweet. This worked out perfectly for me, as I already needed an inverting gain on the tweet.
| B+ time delay relay | cbutterworth | Tubes / Valves | 24 | 31st August 2011 12:53 PM |
| time delay with 2 amps? | thedman | Solid State | 2 | 2nd November 2007 12:22 PM |
| 2pole RC time delay? | AndrewT | Solid State | 6 | 11th April 2006 12:23 AM |
| subwoofer time delay | mart34 | Subwoofers | 14 | 15th August 2004 11:19 PM |
| Time delay without the $600+ expense?? | HobbesJunior | Parts | 7 | 15th November 2003 02:19 AM |
| Page generated in 0.09377 seconds (80.90% PHP - 19.10% MySQL) with 11 queries |
