adjustable time delay - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 24th February 2006, 02:20 PM   #11
Inversely connected drivers is not to everyone's likening !
Charles
Old 24th February 2006, 02:40 PM   #12
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Originally posted by dnsey
Why not just align the drivers? At most, you need 20cm difference.
Because it only makes the on-axis response correct. The only correct solution is electronic delay.
It is possible to achieve analogue delay of up to about 1ms. I used to use LC analogue delays that could do this. They were very large, hand made, and consisted of about one hundred inductors (all carefully adjusted to precise values) and a similar number of polystyrene capacitors (also adjusted). These delays were used in conjunction with phase equalisers to correct delays from routing stereo signals via wildly different paths from an outside broadcast to London Broadcasting House.
Delay is best done digitally - it's the main argument for using a digital crossover.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 24th February 2006, 07:53 PM   #13
back is offline back  Greece
my drivers are placed on a baffle but their acoustical centers
are about 2cm for woofer-mid and about 1cm for mid-tweeter.
there is only one way to solve this problem.
electronic delay.
aligning the drivers would cause more problems than it solves.
sloping the baffle would cause listiening the drivers of axis.
my crossover is 4th order linkwitz riley.
phase invert is not the same with delaying the signal.
it improves frequency responce but impulse responce
and stero image have problems.
mazurek mid - tweeter alignment is more critical than woofer-mid
i checked out the linkwitz link but still didn`t solve my problem.
i don`t know how to make an adjustable circuit.
Old 24th February 2006, 08:16 PM   #14
BobEllis's Avatar
In this post I attached a spreadsheet that includes calculations for an all pass delay. pick a standard cap value, and adjust the resistor to get the offset you want. You may need to add two stages, although 10mm ought to be achievable with just one.
Simply correcting for the difference in acoustic centers will get you close, you can get it better by tweaking slightly to minimize the phase shift between drivers at the XO point. Smoothly changing seems to be more important than an exact match.
Old 24th February 2006, 11:31 PM   #15
should i use figure 7 and replace R1 and R2 with a pot?
10nf and 50k is a good starting point?
sorry for my all those questions but i am knew to all this
Old 25th February 2006, 12:14 AM   #16
BobEllis's Avatar
Use Linkwitz's #4 - Delay correction.
Starting values depend on your crossover frequency of interest. With the values shown in Linkwitz's example, you are about right if your XO is at 2500 Hz. I'd start there with a 5 K pot. If you cannot get enough delay, swap the position of C and R or reverese teh connections to the tweeter. (There is nothing magic about the polarity, what matters is getting the diaphragm moving the right direction at the right time. You can invert the signal electrically or electronically. Once you find the right resistor value, replace the pot with the equivalent resistor. The other resistors in the circuit ought to be the same as R for minimum DC offset.
How did you measure the acoustic centers? the centers of the voice coil gaps are an approximation.
Old 25th February 2006, 12:22 AM   #17
thanks a lot.
i didn`t measure the acoustic centers that`s
why i want it adjustable.
i want to adjust measuring the phase until i get it right.
my crossover points are 300Hz and 5000Hz.
Old 1st March 2006, 07:51 AM   #18
Please be aware that allpass filters do not actually delay the input signal but they shift the phase. With clever choice of dimensioning an allpass can be made to behave like a delay up to a certain frequency. The higher this frequency - for a given delay value - the longer the allpass filter.
Enclosed you can see the step response of a 10th order allpass with a delay of 100us approx. The allpass is consisting of five equal 2nd order inverting allpass sections witha a Q of 0.5 (therefore the output signal is inverted).
The same delay can be achieved with 10 first-order allpass sections like the ones shown on SL's homepage.
2nd order sections have the advantage that Q-values can be chosen at will and they should have a slight THD+N advantage -but first order sections are less demanding regarding loop gain of the op-amps.
One can clearly see that the circuit doesn't give a perfect delay and that higher frequencies are delayed less than the lower ones.
I used a 40 kHz lowpass after the filter in order to emulate the upper cutoff of a tweeter. This signal is shown as well and it looks a little better then the one coing from the allpass directly.
Green: Input step
Red: Allpass output
Blue: lowpass- filtered allpass output
Charles
Old 1st March 2006, 08:01 AM   #19
Here you can see the result for a 10th order Bessel allpass of the same delay approx. The result is definitely better due to less group-delay distortion. But this comes at a price: Only 2nd order sections can be used and tighter parts tolerances are asked for.
Trace colours same as before.
Charles
B+ time delay relay cbutterworth Tubes / Valves 24 31st August 2011 12:53 PM
time delay with 2 amps? thedman Solid State 2 2nd November 2007 12:22 PM
2pole RC time delay? AndrewT Solid State 6 11th April 2006 12:23 AM
subwoofer time delay mart34 Subwoofers 14 15th August 2004 11:19 PM
Time delay without the $600+ expense?? HobbesJunior Parts 7 15th November 2003 02:19 AM
Copyright ©1999-2017 diyAudio
