How do you guys suggest I find out how much gain my phono pre offers? Welborne labs
Old 19th January 2006, 05:12 PM   #1
240z4u is offline 240z4u  United States
Send a message via AIM to 240z4u
Default How do you guys suggest I find out how much gain my phono pre offers? Welborne labs
I have an older, ie early 90s late 80s welborne labs phono preamp. I am trying to find a new cart but have no idea what kind of gain this thing offers. Is there any good way to test or find out?
I was trying to avoid bugging ron at welborne labs.
Evan
Yeah... it seemed like a good idea at the time.
Old 19th January 2006, 05:33 PM   #2
poobah is offline poobah  United States
poobah's Avatar
You should apply a sine wave at the input of about 50Hz.. above or below this and will either get tangled up by the rumble filter or the RIAA curve. Making a signal this small can be hard. Place a 5 or 10 K resitors in series with a 100 ohm resistor. Drive the series string with your signal generator. Use the voltage across the 100 Ohm resistor to drive the cartridge input. Adjust your generator (or the 5-10K) unitl you see about 0.5 VOLT peak to peak OUTPUT on your scope. Measure the signal generator for peak to peak as well. Then calculate the voltage at the input.
Gain (dB) = 20 * LOG [output (p-p) / input (p-p)]
If you don't have all these toys... maybe better to ask.
Old 19th January 2006, 06:53 PM   #3
What you mean its not written in plain english under the circut board or something? haha
Thanks poobah, I definitely do not have those fun toys to use. Maybe Ill ask first!!
Evan
Old 22nd January 2006, 10:05 AM   #4
I would recommend a switched attenuator (Tpad - 600r in & out) before the preamp.
You would need to research the building of this. Just a bank of resistors and 2pole 2way switches.
Then, you stand a chance of measuring the gain fairly accurately.
The idea is to set the input voltage to a value that you can measure. Adjust the attenuator to give a feed into your preamp that produces an output that exactly matches the input voltage. Read off the attenuation on the Tpad. This is your gain.
Because you are comparing the same voltage and the same frequency this method eliminates most of the errors that using a bare DMM would generate.
You can extend the usefullness of your circuit by using it to measure frequency response. Mine seems to work from 15Hz to 200kHz (+-0.05db). The lower limit is set by the sampling frequency of the DMM. I have not properly solved the low frequency measuremnts but by setting an oscilloscpe to no sweep I can estimate the lower end response down to 0.5Hz +-0.5db
Conclusion, you need some equipment. It will be easier to phone or Email the designer.
regards Andrew T.
Old 15th February 2006, 02:24 PM   #5
kevinkr's Avatar
Yeah, I would ask Ron Welborne first, and incidentally phono pre-amplifier gains are generally specified at 1kHz. Pre-amplifiers designed specifically for MM/ high output MC cartridges will generally have gains in the range of 36 - 46dB. Ones designed for low output MC types may be 10 - 20dB higher than this.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 16th February 2006, 12:24 AM   #6
50db is the magic number, thanks ron welborne!
Evan
How do you guys suggest I find out how much gain my phono pre offers? Welborne labsHide this!Advertise here!
FS: Welborne labs DRD300b (UK) mhl888 Swap Meet 0 11th March 2008 01:21 AM
Anyone have a Welborne Labs amp? benm Tubes / Valves 2 9th November 2006 12:33 AM
Welborne labs phono stage needs help, got killed in power surge last night 240z4u Tubes / Valves 0 11th May 2006 02:37 PM
Welborne Labs Mod and ST-70 mstomaso Swap Meet 0 8th August 2005 07:53 PM
Copyright ©1999-2017 diyAudio
