Go Back   Home > Forums > Source & Line > Analog Line Level
Old 14th January 2006, 06:29 PM   #1
astouffer's Avatar
Default Analog Addict's PCB
http://www.fortunecity.com/rivendell...o/aaphono.html
This is my first attempt at designing a PCB so go easy ok Its the Analog Addicts preamp without the coupling caps on the output. The resistors in the feedback loop are physically larger because the schematic calls for .1% tolerance. The .0047uf and .001uf caps are Wima MKP2 while the 47pf and 330pf are ceramic. Although maybe switching to silver mica could improve things.
This layout was done with ExpressPCB although I am trying to learn Protel. The learning curve is a bit steep. Any comments or criticisms are welcome.
Old 17th January 2006, 10:58 AM   #2
hjelm is offline hjelm  Sweden
hjelm's Avatar
c8 and c7 seem to be shorted? It seems that half the supply is shorted to ground at c7 and c6. I can find a path from the right side of the J1 to the middle pin of J1.
/regards
Hjelm
Old 17th January 2006, 11:04 AM   #3
jan.didden's Avatar
/regards
Indeed. A suggestion: move R3, C2 to the left of C7, C8. Then run the trace from R4 etc to R3 etc under C7, C8. Then you can vreate a good ground plane for the supply decoupling caps with short tracks.
Of course, a dual layer would make it even easier.
Jan Didden
/Yes! Its out: Linear Audio Vol 5!
I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun
Another AG9016 "addict" Cees66 Tubes / Valves 3 2nd April 2008 08:38 PM
hello my name is John and i am a audio addict mclsound Introductions 2 18th September 2007 04:32 AM
Analog Addict's (El Cheapo) PCB astouffer Solid State 10 17th January 2006 03:19 AM
Analog VCA's maylar Solid State 7 11th November 2005 03:44 AM
5.1 HT Analog Pre mcp Solid State 0 31st May 2003 02:52 AM
Copyright ©1999-2013 diyAudio
