| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Is anyone familar with this RIAA amp, published by Hi Fi News and Revord Review in the 80's?
I would like to see the schematics if possible. I recall he also had a passive amp in this series. Tom EE |
#2 |
This designation is similar to the Analog Devices AMP01.
Did Ben Duncan use these ICs? Would instrumentation op amps work well for the MM type cartridges? Tom EE |
#3 | |
Audio Synthesis, www.audiosynthesis.co.uk supplies bound reprints of the AMP01 and AMP02 series of articles. I bought them a few years back. Don't see them listed on the website but may still be available. James |
#4 |
I would buy the reprint but its no longer available.
its been a long time and I need to refresh my memory. How does the amp 02 differ from the amp 01? What chips do they use? Thanks Tom EE |
#5 |
Ben D. used opamps that seemed to be just reaching the market at that time. All VERY expensive. By now most of these will be a lot cheaper both in actual cost and in real terms. I suspect a few of them can be replaced with better more modern alternatives. Have you tried the library archive?
regards Andrew T. |
#6 |
No libraries around here carry issues that far back.
But I just need to know the topography used. Was it a 2 op amp passive design? Tom EE |
#7 |
Hi Tom,
The amp 01 is a 3 ic design with mixed active/passive riaa eq. It has/had switched gain to cater for mc and mm carts as well as an option for balanced/unbalanced input. PM me if you want more info on his amp 02 and passive pre articles. Cheers, Steve.
The older I get, the more simplicity appeals. |
#8 | |
If you know the issue in question you can order it from the Document Supply Centre in Boston Spa via your local library. In London, The Science Museum library and the British Library both carry back issues of HFNRR going back to at least the 70's. The IEEE library might also carry it. BTW, If you want to build the AMP02 phono stage tracking down the SSM2016 might prove tricky. |
#9 |
The SSM2019 should work well in place of the SSM2016, but I'm more interested in his reasoning than actually cloning the circuit.
IC's are much better and cheaper than in those days. Tom EE |
#10 |
I doubt this helps but here's some info about Ben Duncan's riaa-equalisation module.
http://mail.google.com/mail/?view=at...265c6d0caedd8d PS I have a little more information,if only I could find it ! |
| Ben Duncan AMP-02 articles anyone? | DoctorRad | Solid State | 2 | 16th May 2008 02:32 AM |
| duncan psu simulation vox ac30cc | Marcelinho | Tubes / Valves | 0 | 19th March 2008 01:04 AM |
| FS: SELF and Duncan books | dimitri | Swap Meet | 0 | 30th November 2006 06:27 PM |
| Duncan PSU Designer II | MattM | Pass Labs | 2 | 2nd February 2005 08:24 AM |
| ben duncan book | dimitri | Swap Meet | 1 | 13th September 2003 08:21 PM |
| Page generated in 0.10181 seconds (85.83% PHP - 14.17% MySQL) with 10 queries |
