Go Back   Home > Forums > Source & Line > Analog Line Level
Old 2nd February 2006, 09:01 AM   #11
Dave S is offline Dave S  United Kingdom
I don't know about the AMP01 but I built the AMP02 many years ago.
It had an error on the pcb whiich caused dc offset at the o/p of the SSM2016, although even when this was corrected the sound was not great.
The SSM2017 actually sounds better than the 2016 and is much easier to apply.
I have full set of AMP02 articles but would not recommend expending any effort on this project - there are many better sounding and much simpler RIAA stages around.
Dave
Old 3rd February 2006, 03:02 AM   #12
tmblack is offline tmblack  United Kingdom
Hello Dave,
I was intrigued by the balanced input which might help with hum.
Which circuits do you like better?
Tom
EE
Old 3rd February 2006, 02:01 PM   #13
Hi Tom,
The AMP02 sounded better when the 2016 was replaced by a 2017. AD845 is also not one of my favourite opamps.
Unfortunately I used silver plated ptfe wire (before I knew better)for the balanced tonearm cable with my Amp02 - this gave a rather bright and spitty sound quality. Reverting to a "normal" arm cable in unbalanced mode gave much better results and hum was never an issue anyway (why try to solve a problem that does not exist?).
A JLH discrete RIAA stage sounded better that the AMP02 (and very similar to a Linn Kairn phono stage). In fact any competently designed 2 or 3 stage phono amp using decent opamps (e.g. AD797, OP27/37 or even NE5534 ) sounds better that the AMP02 IMHO.
What to build instead?
I'm not sure - I rarely listen to records nowadays. Maybe best to look for recommendations from somebody like Werner.
Dave
Old 4th February 2006, 06:09 PM   #14
Is it understood why silver plated ptfe wire gives this sound quality?
How do you ground your tonearm?
Several players I have savaged have horrible hum, like an old Thoren.
Tom
EE
Old 4th February 2006, 08:06 PM   #15
forr is offline forr  France
forr's Avatar
In case it can help, I still havef many of Duncan's articles published in Hifi-News.
~~~~~~~~ Forr
Ben Duncan AMP-02 articles anyone? DoctorRad Solid State 2 16th May 2008 02:32 AM
duncan psu simulation vox ac30cc Marcelinho Tubes / Valves 0 19th March 2008 01:04 AM
FS: SELF and Duncan books dimitri Swap Meet 0 30th November 2006 06:27 PM
Duncan PSU Designer II MattM Pass Labs 2 2nd February 2005 08:24 AM
ben duncan book dimitri Swap Meet 1 13th September 2003 08:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
