FM MPX filter - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 11th December 2005, 08:32 PM   #1
mcs is offline mcs  Denmark
Default FM MPX filter
I'm working on an FM tuner/MPX decoder design, and I'm trying to figure out how to design the audio output filters.
I found a schematic in the LA3410 MPX chip datasheet, but when I simulated it in PSpice, I found out it wasn't that good... Here's a frequency plot:
http://stiftsbogtrykkeriet.dk/~mcs/MPXFilter.gif
Not a lot of attenuation at 19kHz and -3dB somewhere around 13kHz.
The next thing I tried was "expanding" that filter with some extra sections. That produced this result:
http://stiftsbogtrykkeriet.dk/~mcs/F4V10.gif
Good attenuation of 19kHz and above junk, but some ripple in the audio band. Here's a close-up of the 1-50kHz range:
http://stiftsbogtrykkeriet.dk/~mcs/Not_nice.gif
To get a nicer looking curve I tried calculating a standard low-pass filter (6th order Linkwitz-Riley at 25kHz in this case), and then I added some caps accross the coils to create notches. This is the result I got from that:
http://stiftsbogtrykkeriet.dk/~mcs/Nice.gif
Looks very nice in the audio band, but the -3dB point has moved lower, and the 19kHz and above attenuation isn't as good.
So which filter would actually work best and sound best?
I have looked at some Toko datasheets for MPX filters also. They have about 25-30dB attenuation at 19kHz, and some of them higher at 38kHz. But I have no idea what circuit they use. Would they be better, or would a DIY filter with good quality parts (rather than ceramic chip caps) be a better idea?
If anybody has suggestions or experience in this field I would like to hear about it
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 11th December 2005, 09:04 PM   #2
moamps is offline moamps  Croatia
here are filters I use on the tx side. The passive sounds better, IMO.
For more info check the old Revox and Studer tuners schematics.
http://www.prodigy-pro.com/forum/vie...=8107&start=15
Milan
Old 12th December 2005, 01:25 AM   #3
Your schematic is exactly the same as mine
The values are very different though. How did you choose those exact values?
Best regards,
Mikkel C. Simonsen
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
Just one big filter cap or more smaller filter caps ... beppe61 Power Supplies 2 18th July 2006 05:46 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
chassis-mounted filter or IEC plug filter jarthel Solid State 7 11th March 2002 10:17 AM
Copyright 1999-2017 diyAudio
