Coupling Control signals into Audio Lines - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 24th August 2005, 07:58 AM   #1
jenda is offline jenda  Switzerland
Default Coupling Control signals into Audio Lines
Hi all,
I'am wondering how control signals are coupled into audio lines. For example like some walkman/MD player's remotes do.
Does someone have any idea?
Do some chips exist, that are able to do the modulation of control signals (eg. OOK or FSK modulators transmitting on audio lines)?
Kind Regards, j
Old 3rd September 2005, 06:48 PM   #2
metaxus is offline metaxus  Australia
metaxus's Avatar
The portable audio device remote controls don't inject a control signal, per se...
The remote's plug and unit's socket have an extra pair of contacts to carry the remote signals.
There is a different value resistor in series with each switch in the remote control, and the IC for the controls in the unit that measures the resistance across those two pins, compares them to an internal lookup table, and then acts accordingly.
See the attached image to clarify.
Old 6th September 2005, 11:14 AM   #3
lufbramatt's Avatar
hi
ie just done this as part of an electronics module in my design degree. I was able to superimpose 2 control frequencies on the top of a separate carrier wave, ie the sound, by using switched wein bridge oscilators at one end, then filtering them out from the music signal with a pair of opamp based band pass filters. the signals had to be above audio range so they didnt affect the music playing.
My attempt was pretty basic but it worked ok. Wasnt particularly compact either. Im sure theres a easy way to do it with a specialised IC tho!
Splitting line level audio signals squowse Everything Else 0 19th August 2006 04:21 PM
Different ways to transport SPDIF Audio signals oehlrich Digital Source 0 2nd April 2005 04:39 PM
Switching audio signals with relay niral622 Solid State 11 19th April 2004 04:28 PM
combining 2 or more audio signals? r-wu Analogue Source 6 7th May 2003 11:10 PM
Audio Signals Thru 220V Drafance007 Solid State 10 30th December 2002 08:36 PM
Copyright 1999-2017 diyAudio
