Hello there,
im currently building my frist speaker, its gonna be a Battery powered PA-Speaker. i have some problems and some ideas to solve them but i would like your confirmation that this is working
The well known ADAU1701 DSP has a Output voltage of 0.9Vrms, the TPA3255 board by Nobsound ( Amazon.com: Nobsound TPA3255 Digital Power Amplifier Class D Audio Amp Assembled Board 300W+300W HiFi: Home Audio & Theater ) states to have 2Vrms inputs.
So that means when the DSP is running at full Volume, the TPA3255 wont even run at half its maximum power?
As i want to design the Board for the ADAU1701 by myself i have following idea to solve the problem:
at the Output of the DAC's i have to connect OP-AMP which is good for Audio. The Resistors around the OPAMP should then make it to have Amplification of 2,2(Vout/Vin) ... or 6,94dB
Is my thinking correct that the DSP would be bottleneck for the AMP?
And would the OpAmp curcuit solve the problem ?
Thanks for your help
KidCe
KidCe
Yes that works, but opamp output filter is normally not needed, simple RC-filter will also do.
Im not planing to do Filtering with the OPamps, just using the Amplification.
Good pointYou can set the gain on the TPA3255 boards as well by changing the resistor values at the opamps in the front input stage.
<- If link is not working: Rightclick and copy picture adressIf im right this should be the Input stage of the Nobsoundboard.
So i would just have to find out how these OPAMPs are wired and then i can replace the Resistors to my needs by desoldering and soldering in new ones with other values.
I Couldnt find high res Picks of the 3e Audio TPA3255 board to look how the Inputstage is made there but it should be somewhat similar but with jumpers for Single ended / Differential input.
Maybe ill go with the 3e Board when its available again.
