I want to try two chinese mono pcbs for building a JC-2 clone. This pcbs where very cheap
and seems of quite well quality.
The FETs has to be K170 / J74.
What IDSS I need? BL, GR or V?
Can anyone help?
Can anyone help?
The core of the scheme - input differential stage, which named “four-quadrant self-biased”, works at ~0,8-1mA.
So you can pick any grade tight-matched quad.
John Curl's ORIGINAL JC2 schematic, which he published in The Audio Amateur, used JFETs part number E175 and E212. Today you can buy the 175 in thru hole Mouser link #1 but you can only buy the 212 in surface mount Mouser link #2
This is a modified JC-2 circuit. The input devices could be 2sk170, 2sj74 Yellow as the input stage runs at such low current, but matching is going to be tough for an amateur. An easier choice is a matched set of American jfets like the j113, j174 complements, but they will be tough to get also. Darn, I don't know what to recommend.
You can (still) get 2SK170GR / 2SJ74GR matched pairs, genuine, if you are willing to pay.
http://www.diyaudio.com/forums/pass-labs/317563-replacement-toshiba-2sk170-2sj74-11.html#post5429153
40 USD for 2 channels.
Just ask him even if he does not have them listed currently.
He has stock.
Patrick
He has stock.
Patrick
How is it possible to get a higher current from these boards?
You need to provide Vbe of the second stage drop on the R2 and R4.
Changing them together with VR1 setting will allow you to tune idle current of the input stage. But keep in ming higher dissipation, noise and bias.
Also you can alter second stage to a common base like this:
Doing this would free second stage from Cob influence from relatively high VAS output voltage.
- Analog Line Level
- Which FETs for JC-2 preamplifer?
