TakeT soundstage activator
Old 16th May 2018, 03:24 PM   #1
sumotan is offline sumotan  Indonesia
Default TakeT soundstage activator
TAKET| Soundstage Activator | TakeT-SA(u).
Hi Guys
Whatís your view on this ? Makes some good reading though, very curious about whats inside this little box.
Cheers
Old 18th May 2018, 10:16 AM   #2
lcsaszar is offline lcsaszar  Hungary
A resistor?
Old 18th May 2018, 10:27 AM   #3
Itís very unusual in its connection. It only takes in the left & right channel with no output.I believe speaker wires are still connect as normal with jumper wires to the TakeT. Wonder itís some sort of mixer delay network that is send out to mix with the original signal.
Btw they have another version which states balance out now this is also a head scratcher. Amp out is always 2 wires per channel so whereís the balance signal coming from ?
Old 18th May 2018, 05:41 PM   #4
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
Hi Guys
Cheers
The only function I can readily imagine is to decrease the stereo seperation between channels. Essentially, a mono blend circuit. Except that, placed across the power amplifier's output terminals as shown it would need to severely load down the output to do so. Doesn't make sense to me and appears to be snake-oil product.
TakeT soundstage activatorHide this!Advertise here!
drivers with big soundstage ? goodjingan Multi-Way 56 17th October 2014 07:30 PM
Soundstage mjock3 Tubes / Valves 23 16th June 2013 02:42 PM
Soundstage Help easymac77 Analogue Source 8 18th July 2010 02:14 PM
Help me with set up issue - soundstage sqlkev Multi-Way 19 27th July 2006 07:04 PM
visualise soundstage neutron7 Everything Else 0 14th February 2005 07:39 PM
