Hum noise on pre amp vintage
Old 17th May 2018, 03:14 PM   #11
stocktrader200 is offline stocktrader200  Canada
the 56k, 2.2k and 330pf cap form the NFB loop for the old chip. connecting that to the AX14 will duplicate the function of the similar loop in the AX14. It should be removed.
Usually an amp won't run long with a shorted power supply diode. This does explain the main source of noise.
The AX14 should be silent with no input and the signal ground tied to the star ground point.
Old 17th May 2018, 07:15 PM   #12
ThiagoOliveira is offline ThiagoOliveira
Ok, I had bypassed these components.
I notice that it picks up a lot of noise from anywhere.
I'll follow your suggestion and increase the value of R8.
The phono stage also uses the HA1457, but it looks like it's okay.
I'll do that tomorrow and post the result here.
Thankful!
Old 18th May 2018, 09:19 PM   #13
Today I changed the R8 value of APEX AX14 from 560R to 1K and heard practically no noise! Maybe I'll try 1K2. I will seek perfection!
Thank you all!!!
Hum noise on pre amp vintageHide this!Advertise here!
Verifying Picofarad lvl Vintage Capacitors From BF-50 Vintage Cap Tester? ZoSoNCSU Equipment & Tools 7 7th April 2018 04:13 PM
List of Tube Noise Measurements - please nominate lowest noise tubes TavishDad Tubes / Valves 326 2nd February 2018 01:41 PM
Vintage Punch 100ix noise chasing judah304 Car Audio 4 15th August 2017 12:33 PM
Flicker Noise dominates triode noise in audio (AES) ruffrecords Tubes / Valves 68 22nd October 2014 07:59 PM
Vintage Richard Long Bertha/vintage JBL artscrafts14 PA Systems 6 5th July 2012 07:19 AM
