Another can of worms...
Old 29th May 2018, 04:46 AM   #31
johnego is offline johnego  Indonesia
Originally Posted by troystg View Post
All,
C18 and C19 are listed as .005uf (5000pF) caps.. I am switching to Wima caps and they don't have a .005uf in that physical size.
It's either 4700 or 6800 pF.
Any suggestions on which way I should go?
Since C16 should be twice the C18 (to maintain the proper transfer), there is a useful trick to use any value on C16 and use parallel of the same value on C18. So if C18 is 4.7nF, C16 is 2x 4.7nF (equal 9.4nF). In crossover design this is a neat trick (there are situations you need it) if your parts are small (e.g. SMD or 1/8W resistors, 63V capacitors).
Regarding the better values, I think it is more important to know which crossover frequency is better. If 5nF gives 113Hz then 4n7 will give higher frequency, which IMO is probably what you should want. (Because at 113Hz the initial speaker response might not be that flat)
Old 29th May 2018, 10:43 AM   #32
troystg is offline troystg  United States
troystg's Avatar
Thank you both for the input and information! Much appreciated.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 30th May 2018, 08:44 PM   #33
PRR is offline PRR  United States
PRR's Avatar
4700 vs 5000 is 6% or one semi-tone. Very few crossovers need to be that exact. Driver capabilities suggest 400Hz or 600Hz for different goals; I can't think why 500Hz or 532Hz makes the least difference.
However, to be picky: take the cap you can get and then adjust the resistor value. Resistors are available in much narrower bins than capacitors. If, say, 5000p and 100K rings your bell, then 4700p and 106.38K hits the same point. (and 105K is all the same considering your "4700p" may be a few % out.)
Another can of worms...Hide this!Advertise here!
Opening a can of worms but...how do you calculate the slope inside a TL enclosure Rino odorico Multi-Way 17 26th August 2002 05:57 PM
Can of worms anyone ??? BR vs. IB Simon Multi-Way 0 30th July 2001 07:12 PM
