Magic Acoustic Scene Rebuilder
Old 12th March 2018, 12:20 PM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default Magic Acoustic Scene Rebuilder
if you like the sound of vinyl
then you must try this scheme
the gain is 4
you need a balanced output DAC
and the phase of the right speaker must be turned around
apparently useless
this preamplifier
it produces an extraordinary dynamic
and finally returns the center of the scene
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 12th March 2018, 08:03 PM   #2
Oscar-san is offline Oscar-san  Italy
Don't work...
Old 13th March 2018, 08:43 AM   #3
Stee's Avatar
Default do not ask me
how does it work
because I do not know
The best
discoveries
they happen by chance
however it works
Old 13th March 2018, 11:25 AM   #4
DF96 is offline DF96  England
Yet another crazy idea.
Old 13th March 2018, 11:46 AM   #5
This is a null test
Old 13th March 2018, 12:16 PM   #6
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
the gain is 4
and the phase of the right speaker must be turned around...
As simple as that wiring diagram is, it's still confusing. Are XLR pins L2 and R3 directly tied together for one channel. Then, R2 and L3 for the opposite channel, I suppose? Doesn't this then short together the L and R output drivers, which are each attempting to drive a different signal? As for Pin 1, it connects to the chassis/safety ground, and is not even a signal pin. Further, pin 1 almost certainly introduces common-mode noise to the whole affair.
As for what pleasing effect this might produce, I can only think that it is due to altering/distorting the inter-channel signal difference information. Which is what makes stereo, well, stereo. Without which, it's mono. In terms of music listening, this then would alter the ambient sound presentation to unpredictable affect. Perhaps, it's a bit entertaining at first, but over the long term? Whatever fidelity this produces, it would not seem to be authentic.
Old 13th March 2018, 04:44 PM   #7
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
This just seems to be a line level L+R circuit, with two out of phase outputs as set up. I fail to see the reason behind it.
Check out My 6SN7 Push-pull Flea Amplifier project!
Old 13th March 2018, 06:15 PM   #8
Stee's Avatar
Default ASR - Acoustic Scene Rebuilder with Jfet Buffer
maybe it's an sum effect
same of Vinyl Pick-Up
so the bass wave is in opposite phase
between two channel
Old 13th March 2018, 06:43 PM   #9
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
More circuit has magically appeared.....
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Magic Acoustic Scene RebuilderHide this!Advertise here!
Acoustic Scene rebuilder Stee Solid State 0 13th December 2017 08:57 AM
A mod/challenge for you speaker builder/rebuilder geniuses!!! folkie13 Multi-Way 8 19th August 2015 05:41 AM
State of the Hi Fi scene.. afa The Lounge 11 18th December 2014 08:59 AM
backing out of the DIY scene dunderchief Multi-Way 37 19th October 2005 05:09 AM
Wtd: APT Holman Rebuilder Recommendation LesConnally Solid State 3 24th June 2005 02:54 AM
