programming FIR Filters for the ES9018 DAC as a cross-over?
Old 6th February 2018, 08:47 PM   #1
marcelooms is offline marcelooms
Default programming FIR Filters for the ES9018 DAC as a cross-over?
According to the data sheet, the ES9018 can be programmed to use custom coefficients in the 2 stage FIR filter.
The way how to enter the coefficients is the registry is described quite clearly. But does anyone know to calculate these coefficients?
Each of the 8 channels can be programmed to have its own filter. Would it not be an ideal solution to making it a great and simple cross-over?
I now run the cross-over on the PC, sending 8 channels over USB to XMOS and than to 4 I2S datalines to the ES9018.
If I knew how to model the filters, I could skip the PC filters.
I have been looking everywhere invain for information on it, and I'm no FIR/DSP expert. Does anyone know how to do this?
Old 6th February 2018, 09:13 PM   #2
TNT is online now TNT  Sweden
The ADC version has a broken programming function. Maybe the DAC works?? I cant recall anyone doing it.
Its programmed by entering biquads into a register. To know the registers one needs to sign a NTA with ESS.
It's a somewhat tuff territory...
More distortion to the people!
programming FIR Filters for the ES9018 DAC as a cross-over?Hide this!Advertise here!
PIC programming deafbykhorns Software Tools 122 6th January 2017 01:08 AM
What capacitors in cross-over filters? jacques54 Multi-Way 15 25th May 2006 10:17 PM
PIC programming serosmaness Digital Source 12 6th February 2005 10:33 PM
PIC programming future Parts 33 4th June 2003 04:26 AM
