Budget active 3 way crossover - buy, eval, mod
Old 29th June 2018, 01:12 PM   #31
DonVK is offline DonVK  Canada
DonVK's Avatar
That's correct, this XO is fixed gain, but there are a few other places you could adjust the channel gains. It depends on your system and what's more convenient for you. My master volume control is in the DAC, and I'm using Sure class D amps with "fixed" (preset) gain that is set via dip switch (MF, HF) or a pot (LF).
1) select the amp fixed gain (some Sure class D amps have [25.6, 31.6, 35.1, 37.6 dB] settings
2) use amp variable gain (some Sure amps have a volume control/attenuate board) adjust for the diffs and leave it
3) use amp gain offsets, often in HT amps if you are repurposing one, it allows a delta adjustment per channel
4) put an L-pad on the tweeter
5) EQ the channel gain differences at the signal source (using EQ-APO, or FIR filters), you may end up needing this due to unruly drivers, user FR curve preferences, enclosure or room behaviours.
Sure Electronics AA-AB33184 4x100W TDA7498 Class-D Amplifier Board
AA-AA11117 Digital Volume Control Kit
Old 29th June 2018, 02:34 PM   #32
keilau is offline keilau  United States
I have 3 old fashion linear power amplifiers (6 channels). They have no input volume control. The 2-way board I purchased does have LP, HP and master volume control. I will wait a few more days to see if the seller will provide more information.
Another option is this fully assembled crossover box. The seller promises customized crossover frequency.
2 Ways 24dB/Oct Linkwitz-Riley Active Crossover Electrical Frequency Divider | eBay
Old 29th June 2018, 02:55 PM   #33
DonVK's Avatar
Usually, boards like the one you ordered have master volume and tone controls. There is not enough info to tell what the extra controls are actually doing.
It's very easy to add a simple 2 resistor signal attenuator (fixed gain) to the HF output of your XO before the amps. Or you could add a pot between the XO and amp input if you wanted it variable attenuation.
Old 29th June 2018, 03:34 PM   #34
The 3 dual ganged potentiometers are marked bass, treble and master on the circuit board. It is possible that they are volume and tone control. No way to tell until the seller send a schematic. The 2 sided board is hard to trace without removing the components.
Budget active 3 way crossover - buy, eval, modHide this!Advertise here!
Budget HT with Entry Level Active XO(s) ODougbo Multi-Way 4 23rd May 2016 02:21 PM
Current options for a budget active LLXO? enkidu1024 Analog Line Level 16 17th July 2014 11:01 PM
Unity Horn - budget drivers, active x-over jmorken Multi-Way 118 14th February 2014 07:53 PM
Need Advice on designing a budget active speaker mertol Multi-Way 36 25th November 2011 11:54 PM
Budget Active nearfeild monitor: Edifier R1200 DcibeL Parts 0 18th February 2009 05:38 PM
