Budget active 3 way crossover - buy, eval, mod
Old 4th February 2018, 09:50 PM   #21
Soldermizer is offline Soldermizer  United States
Soldermizer's Avatar
Default The solder-averse budget method...
If you can bring yourself to consider a PC based DSP, these could be done as cheaply as a PC that will run DSP software (such as J River Media Center); you can get PCs well < $200 that have HDMI out (such as Pipo X9), feed HDMI to a cheap 5.1 or better HTR and you have, effectively, a multi-channel DSP to use as you like.
Performing unnatural acts to circuits since age ten
Old 4th February 2018, 10:19 PM   #22
DonVK is offline DonVK  Canada
DonVK's Avatar
Nothing against DSP approaches, its often the only way to do certain things. I have used my PC with APO equalizer's convolution engine and Rephase to generate filters for both the room and the speaker. I also have another thread trying to do a similar thing on an RPI which is where I would prefer it. After I get basic EQ and a convolution engine working on the RPI, I plan on trying a s/w crossover as well. Maybe both will be used, a hardwired filter is safety from rogue s/w.
Old 5th February 2018, 07:24 AM   #23
zdr is online now zdr  Belgium
zdr's Avatar
I have been using FreeDSP and never looked back.
Neb. [LDR Volume Control OLED firmware:]
https://drive.google.com/open?id=0B7...ENmRXNYUEtySVE
Old 5th February 2018, 09:14 AM   #24
R.I.P.
thanks for the name.
Didn't know anything like that existed.
Do you have any recommendations?
regards Andrew T.
Old 5th February 2018, 05:07 PM   #25
DonVK's Avatar
Default Distortion
The following are measured with REW and a PC soundcard (24b). The graphs are scaled so that the max line in = 0db. So I adjusted the output such that the max signal into the soundcard is -3db to avoid clipping. It also means that the soundcard output can't be maxed because of the gain at the active XO input.
In all cases the TH is -80db which I'm good with. Its hard to determine if its the XO or the PC sound card that's the limiting factor here but I suspect the PC. I also need to clean up some switching noise from the SMPS. Then I might try a different setup that would allow me to figure out the actual noise floor on the XO and if I can push the TH a little lower.
Old 10th February 2018, 03:22 AM   #26
DonVK's Avatar
Default Noise
I don't have equipment or a method of proper noise measurement other than time waveform and an oscilloscope. There is some SMPS HF noise present, and the XO board lacks HF decoupling. This test was with the inputs shorted to ground and a 10K load on the outputs.
The on board regulators attenuate some of the lower freq SMPS variation. Pic#1 show the ac component of the +15vdc rail with the mid outputs (M) as a wide view. Pic#2 shows the zoom in of the ac components of the +15VDC and the low (L) outputs. Pic#3 is a zoom in of the ac components of the +15VDC and the high (H) outputs. Pic#2 and #3 show the onboard regulator helps for some variations, but the HF goes through everything. A power filter will be added after I test a few other related pieces of equipment.
Old 3rd June 2018, 07:23 PM   #27
DonVK's Avatar
Default packaging
Finally got around to putting it in a box. The fan will eventually something like a LM317 based speed control to make it quieter. There is enough room left for additional boards. The current FR is shown with the mod'd sub bandpass.
I'm getting closer to deciding on the final 3way XO points that I want. Each driver would handle 2.5 octaves and behave well in the XO overlaps.
sub : 20-100Hz
woofer : 100Hz-600Hz
mid : 600-3.6Khz
tweeter : 3.6Khz-20Khz
Old 7th June 2018, 03:25 AM   #28
keilau is offline keilau  United States
sub : 20-100Hz
mid : 600-3.6Khz
How do you roll off the woofer below 100Hz? The woofer and the subwoofer seem to have the same SPL from 30 to 100Hz. Will this arrangement make the sub-100Hz range 3dB louder the rest of the sound spectrum?
Old 7th June 2018, 04:23 AM   #29
DonVK's Avatar
The woofer will have a sealed chamber, so it will have a -12db/octave acoustic rolloff at 100Hz. Still, the slopes are different (sub -24db, woofer -12db) so a small bump could occur. The sub's volume (gain) and XO point are adjustable for this reason.
Budget active 3 way crossover - buy, eval, modHide this!Advertise here!
Budget HT with Entry Level Active XO(s) ODougbo Multi-Way 4 23rd May 2016 02:21 PM
Current options for a budget active LLXO? enkidu1024 Analog Line Level 16 17th July 2014 11:01 PM
Unity Horn - budget drivers, active x-over jmorken Multi-Way 118 14th February 2014 07:53 PM
Need Advice on designing a budget active speaker mertol Multi-Way 36 25th November 2011 11:54 PM
Budget Active nearfeild monitor: Edifier R1200 DcibeL Parts 0 18th February 2009 05:38 PM
