active crossover Kaneda
Old 5th February 2018, 03:42 AM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
cleaned up Soundhappy’s posted scematic
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th February 2018, 09:53 AM   #22
R.I.P.
Are there a couple is misprints in the low pass MFB filter?
I see two capacitors marked in mF, whereas all the others are in nF.
The lower supply rail electrolytic is shown with +side attached to the -30Vdc !
The high pass is operating on +-30Vdc supply rails. There is adequate headroom for high level transients.
The low pass is operating on +-15Vdc supply rails, that reduces the headroom significantly, maybe -6dB.
There is a summing stage at the input and this stage is set to a gain of +6dB. That gives a gain of +12dB which when combined with the lower supplies effectively means the low pass stage will overload with signals ~18dB lower than the high pass.
Is this the right way to do it?
regards Andrew T.
Old 5th February 2018, 01:05 PM   #23
adason is offline adason  United States
adason's Avatar
fixed!
thanks Dave for cleaning up.
Old 5th February 2018, 01:21 PM   #24
adason's Avatar
I had limited time to do any measurements...I still need to order some capacitors to fine tune the high pass crossover frequency. I am looking for 150Hz.
I am not building the low pass, I have few boards from ebay with variable crossover frequency just for sub.
Well, the critical is Re or that 100 ohm resistor in first buffer. That affects the distortion spectrum. My external sound card is not recognized by my old laptop anymore, where I have measuring software, like holm, rew or right mark...so I am using just the headphone output and line in/mic input on crappy laptop. Just a loop out/back in is showing distortion, crappy convertors.
Anyway, I can definitely see the second harmonic missing. With Re being high, like 1-2k ohm, distortion is about 0.8%, which is too high. Going down with value to few hundred ohms distortion drops to 0.1%, with just 120 ohm distortion is about 0.07%, but this in reality is lower, since my laptop is adding its own. I did not continue lower...first I need to get better laptop with external sound card.
Old 5th February 2018, 03:25 PM   #25
R.I.P.
Ada,
the two 100nF on the output are almost operating as filters of the audio band.
F-3dB ~80Hz when feeding into 100k.
If you feed into 10k, then you should be using ~1000nF to get the filtering effect far enough below the 100Hz audio band and thus avoid audio band distortion.
regards Andrew T.
Old 5th February 2018, 04:55 PM   #26
adason's Avatar
Originally Posted by adason View Post
I guess there should be one more buffer on the output, since it uses one more high pass, to decouple it from next stage...
Exactly what I said.
Old 5th February 2018, 09:43 PM   #27
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
As promised, here are the plots for the response of that (corrected) circuit,
showing the high pass, low pass and summed for the parameters of
frequency response, phase response, and group delay.
I don't think I made any errors, but feel free to point them out.....
Old 6th February 2018, 01:02 AM   #28
adason's Avatar
Thanks Nelson, looks almost spot on.
Old 6th February 2018, 01:26 AM   #29
Pano is offline Pano  United States
Pano's Avatar
I remember the Keneda crossover from the old days in Paris. Heard it used on a number of systems. It was super clean, that's my memory of it. Transparent.
Take the Speaker Voltage Test!
Old 6th February 2018, 01:58 AM   #30
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Originally Posted by Soundhappy View Post
Original Kaneda 4 way active filter DIY publication
Amusing vintage solid state active filter.
Thanks Soundhappy for all the beautiful pictures, glad to see you back!
active crossover KanedaHide this!Advertise here!
Do i need analog active Crossover or Digital Crossover for DIY home theatre speakers? dipankar862 Multi-Way 43 16th March 2017 05:55 AM
Help needed to decide: DIY Active Crossover or Passive Crossover? raelman Parts 5 1st October 2014 03:19 PM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
Active Crossover: Behringer x DBX active DriveRack 260 murillollirum Multi-Way 21 9th February 2013 07:12 AM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
