active crossover Kaneda
Old 4th February 2018, 02:57 PM   #11
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Default Kaneda 3 way active filter from " Stereo Technic " 1974
Originally Posted by adason View Post
Thanks Soundhappy for all the information.
Thanks Adason indeed for interesting active filters thread
Version in Your post #1 was dedicatet originaly for small 2.1 audio system.
Sunday morning in my library I find Kaneda publication in " Stereo Technic " january 1974
about 3 voice and 4 voice active filters DIY with filters and psu schematics and first prototype builds photo's
class A amplifiers with full range speakers
sings like angels in heaven
Old 4th February 2018, 03:22 PM   #12
Soundhappy's Avatar
Default Kaneda 4 way active filter from " Stereo Technic " 1974
Original Kaneda 4 way active filter DIY publication
Old 4th February 2018, 05:10 PM   #13
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Over in the PL forum I was pointing out that the schematic in the first post
here is interesting because it has two buffer stages, with filter circuits in
between, that use a depletion mode Jfet self-biased with a bipolar transistor.
The first is an N channel Jfet with PNP bipolar and the 2nd is a P ch Jfet with
NPN bipolar. Presumably this was for cancellation of the opposite 2nd harmonic
distortion of both buffers.
Old 4th February 2018, 06:00 PM   #14
adason is offline adason  United States
adason's Avatar
I made quick prototype today, and it seems to be working ok. I have not made any measurement, as my equipment is very limited. However, it sounds just fine.
Old 4th February 2018, 06:04 PM   #15
adason's Avatar
I made few active crossovers with BJT in the past, 2way, 3way, like Soundhappy just posted. Worked ok, just did not sound as good as B1 and JLH buffer based crossovers.
Old 4th February 2018, 06:12 PM   #16
adason's Avatar
Yes, it seems like a well designed circuit.
I guess there should be one more buffer on the output, since it uses one more high pass, to decouple it from next stage...
Old 4th February 2018, 11:14 PM   #17
Jonathan Bright is offline Jonathan Bright  Australia
Hi adason you mentioned JLH buffers. Can you be a bit more specific pls?
I have a lot of JLH schematics and I was wondering which one you were referring to.
I think I recall see both a complimentary BP transitor and a JFet based buffer but am getting forgetful these days......perhaps they were combined......
Grateful for any further enlightenment.
Cheers Jonathan
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 5th February 2018, 12:44 AM   #18
adason's Avatar
Cheers Jonathan
Old 5th February 2018, 01:06 AM   #19
Thank you. JB
Old 5th February 2018, 01:51 AM   #20
gadut is offline gadut  Indonesia
gadut's Avatar
I'm glad that you are back
active crossover KanedaHide this!Advertise here!
Do i need analog active Crossover or Digital Crossover for DIY home theatre speakers? dipankar862 Multi-Way 43 16th March 2017 05:55 AM
Help needed to decide: DIY Active Crossover or Passive Crossover? raelman Parts 5 1st October 2014 03:19 PM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
Active Crossover: Behringer x DBX active DriveRack 260 murillollirum Multi-Way 21 9th February 2013 07:12 AM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
