Help with one button relay input switching
Old 18th January 2018, 11:47 AM   #21
satx is offline satx  United States
Originally Posted by Gusser View Post
You can use PNP but then everything is backwards so to speak.
The emitter goes to VCC.
The collector goes to the relay coil (+ side if any)
The other side of the relay coil is grounded.
The base needs a low value resistor in the hundreds of ohms range and turns on the relay by taking that resistor to ground or below 0.6v, opposite of the NPN version where the relay turn on by taking the resistor to V+.
You should pull the base up to VCC with about 47K to make sure it stays off when expected to.
You still need the diode with the anode to ground and the cathode to the PNP collector.
If still using the 4017, now you need and inverter for each relay driver. Far better IMO to just buy some 2N3904's. They cost pennies.
Thanks for the explanation. I'll just pick up some 2N3904's! The relay input board I'm using already has a diode for each relay (see the link in my first post) do I need another diode?
Old 18th January 2018, 11:58 AM   #22
Originally Posted by Mooly View Post
Missed your reply yesterday.
As the others have said, the transistor has to be NPN for simplicity.
You could use two PNP's plus another resistor per relay but then you more than double the component count.
No problem, I'll get the NPN's.
Just to clarify- I connect one lead of the a 5,6K resistor to pin Q1 on the 4017 and the other side of that resistor to the center lead of the transistor. One of the remaining transistor leads goes to ground and the other to one relay V+ in. Repeat for Q2 and Q3 and connect the reset on the chip to Q3. Right?
Old 18th January 2018, 05:55 PM   #23
Mooly's Avatar
Middle legs, left legs, right legs... no no no I can't work like that
Look at the data sheet for the transistors you are going to use. The base of the transistor connects via a resistor to the desired output pin of the 4017.
2N3904 Data Sheet
The collector of the transistor goes to the positive voltage supply.
The emitter drives the load, your relay. It is important to get the relay the correct way around if it has an integral diode. Get it wrong and the diode will short the supply out as the relay operates.
You should try rigging up one relay to the supply and make sure it works OK. Just one relay, one transistor and one resistor.
Then wire it to a transistor and make sure that the relay clicks on and off as you connect a 5k6 resistor from the base to the positive supply.
Old 18th January 2018, 06:16 PM   #24
russc is offline russc  England
ULN2003 chip to drive the relays is very cheap and simple - no base resistors, no diodes, all is included in the chip.
Old 18th January 2018, 08:01 PM   #25
Gusser is offline Gusser  United States
Yes, that is an excellent solution for this guy!
Old 18th January 2018, 09:39 PM   #26
Ok, so which is the better solution? As I understand it the ULN2003 still needs arduino.
Old 19th January 2018, 07:27 AM   #27
Mooly's Avatar
The 2003 is simply an array of transistors connected in a Darlington configuration. Its an ideal solution if you want to go that route.
The common diode pin of the chip would connect to the ground pin.
Old 19th January 2018, 12:41 PM   #28
Ok, just so I'm clear.
The 2003 does need a logic input, correct? But no additional parts?
The 4017 doesn't need the Arduino, but will require a number of discrete parts.
It does sound like the 2003 might be the simpler, cleaner solution.
Old 19th January 2018, 01:43 PM   #29
Mooly's Avatar
No Arduino needed for any for this.
Yes, the 2003 needs a logic input in the 5 to 15 volt range. No other parts needed for the 4017 beyond the switch and a resistor.
Old 19th January 2018, 01:45 PM   #30
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Switch into set/reset circuit (debounce's switch) then into D-type flip flop driving transistor into a relay.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Help with one button relay input switchingHide this!Advertise here!
Controlling a latching relay with a single button? curupa Parts 3 27th October 2012 06:18 AM
Question regarding Max. Switching rate push button for Class-D amp + accessories eladmi Class D 3 24th October 2012 12:08 AM
Switching loudspeaker with relay quietdragon Solid State 8 3rd November 2011 04:46 AM
need dpdt switching relay help subaruzero Parts 1 27th September 2006 07:27 PM
Relay switching circuit please jnewbold Solid State 10 3rd March 2005 06:39 AM
