Simplistic balanced preamp/buffer
Old 30th December 2017, 03:35 PM   #11
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
You appear to have a very high end amp there, are you certain you need to go balanced or have a buffer? Often less is more
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 30th December 2017, 03:46 PM   #12
cypher is offline cypher  Poland
Unfortunately this amp has only XLR input and my DAC has only RCA output ;-( I could go for simple conversion XLR > RCA (shorting pin 1 and 3) but this seems to be bad idea.
Further more, for sure my DAC is not designed to drive such low impedance ..
BTW. If my amp using XLR connection has 1.8 kR input impednance how much i will get shorting pin 1 and 3 ? Will it be the same as XLR ?
Old 30th December 2017, 03:47 PM   #13
R.I.P.
Originally Posted by xrk971 View Post
Can you point to a link for the schematic that is easier to find? The links in Post 1 are all broken. I hate threads that hide the schematic.
Not all.
Others found the link. It's right at the end of post1.
I do agree that we Members should be attaching all our information.
I have been championing that for years. The Forum did promise that the new software, two or three generations ago, would only allow attached info and block remote servers. But that never happened.
regards Andrew T.
Old 30th December 2017, 05:35 PM   #14
It depends, table 3 here may help Balanced Line Technology
Could you bypass the balanced line receiver?
Old 30th December 2017, 07:26 PM   #15
Thank you for the link, tons of information ..
Old 30th December 2017, 07:29 PM   #16
You're welcome, it's very useful and clear
Simplistic balanced preamp/bufferHide this!Advertise here!
WTB Salas Folded Simplistic Phono Preamp PCB damuffin Swap Meet 2 10th July 2015 04:53 AM
Balanced Buffer Needed with a Balanced Volume Control? DualTriode Analog Line Level 5 9th September 2012 04:37 AM
OLD THREAD Simplistic Mosfet HV Shunt (The Simpler Simplistic Design by Salas) quanghao Quanghao Audio Design 460 6th May 2012 11:13 PM
