Setup: One TDA8932 for tweeter, another TDA8932 for woofer. Will play from: MP3, Smartphone.
I would like to hear your opinion on which of the 4 options below is the best at giving me the most volume and still being safe?
•Connect tweeter's amp to 3.5mm plug as R channel (ring), woofer's as L channel (tip)
•Connect both to L channel (tip of the 3.5mm jack)
•Bridge 3.5mm plug's L and R pins (tip and ring) without resistors
•Bridge 3.5mm plug's L and R pins (tip and ring) with summing resistors of 1K or similar (Will the volume drop?)
The last option is best
Thanks. Do you believe the volume won't drop by 6db after doing this?
- Analog Line Level
- 2 Way Bi-Amped Mono wiring to aux plug
