Correct way to connect VU Meter
Old 22nd March 2018, 07:52 AM   #41
Mooly's Avatar
It looks like the LED backlight supply is connected to the two lefthand pads of that group of four. Beware of polarity and voltage.
Next pad appears to be audio ground (speaker -) and the right hand pad goes to speaker +
Old 22nd March 2018, 07:55 AM   #42
Zelimir62 is offline Zelimir62  Serbia
I'm not familiar with these. There is PCB with them, not naked instrument. In the central part there are two LED light connectors and two connectors for the VU instrument. You should draw a schematic of that PCB with all the elements in order to figure out what to do. Try to ask for the schematic from the seller with the parameters of the instrument.
Old 22nd March 2018, 11:51 PM   #43
Maverick2020 is offline Maverick2020  Australia
I got this back from the Seller. So I guess I should solder the led legs and the gauge tags that are poking through.
Does anyone have a schematic of how I wire this with a Stereo Log Volume Pot?
Old 23rd March 2018, 07:49 AM   #44
Yes all of them should be soldered on PCBs. The trimmer on the PCB potentiometer adjusts the VU meter display.
This VU meter should be connected to the output of the amplifier, not to the potentiometer.
Correct way to connect VU MeterHide this!Advertise here!
Impedance-meter add-on for the simplistic THD meter Elvee Equipment & Tools 1 9th February 2013 07:58 AM
A LED meter, Volt meter, power meter or light indicator... a nice gadget destroyer X Solid State 5 25th February 2011 06:30 PM
connect my analogue VU meter after Preamp? motbuddy Chip Amps 2 15th July 2010 11:42 AM
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
