Counterpoint SA-3000 Service Manual
Old 3rd December 2017, 06:42 PM   #1
tenelson is offline tenelson  United States
Default Counterpoint SA-3000 Service Manual
I'm looking for the service manual for the Counterpoint SA-3000 Preamp. I know the designer used to sell it, but he has since closed up show.
The particular problem I'm having is that the IREF LED, LED503, is not lit, which indicates the high voltage section is not functioning. In addition, the 555 timer that switches the relay is not turning activating. These things worked before a recap, so I suspect I lifted a pad, but I need to know where.
Old 3rd December 2017, 10:24 PM   #2
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Got some stuff but this is all
Cheeres George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 3rd December 2017, 11:03 PM   #3
rayma is offline rayma  United States
It's probably the timer circuit. If the timing capacitor is a large value electrolytic,
you may have to use a special low leakage type for the circuit to work properly.
The capacitor leakage "resistance" has to be much larger than the timing resistor feeding it.
Old 4th December 2017, 01:53 AM   #4
Thanks to George for the schematic sections.
Rayma, is the capacitor resistance essentially ESR? So I should be looking for a cap with a large ESR?
Old 4th December 2017, 03:53 AM   #5
PRR is offline PRR  United States
PRR's Avatar
Not ESR, leakage.
99% chance a fresh modern cap will be fine. Leakage today is much less than before.
Old 4th December 2017, 03:07 PM   #6
No, something like these. If the timing resistor is say 100k or more,
this could be the problem. It's happened to me before.
Nichicon Low Leakage Aluminum Electrolytic Capacitors Nichicon Aluminum Electrolytic Capacitors - Leaded | Mouser
Counterpoint SA-3000 Service ManualHide this!Advertise here!
Service manual for Counterpoint NPS 200 DarkWingDuckTR Tubes / Valves 9 16th October 2017 08:20 PM
Denon DP 3000 Service Manual Needed reidabix Analogue Source 5 21st June 2016 05:58 PM
Counterpoint SA 5000 Service manual and PSU kannan_s Tubes / Valves 2 7th April 2016 04:45 PM
Tensaļ tuner TT-3000 service manual wanted alayn91 Analogue Source 0 30th November 2014 04:57 PM
Counterpoint Service manual wanted lt cdr data Tubes / Valves 26 29th June 2009 04:10 AM
