op-amp based, high-gain, high rail voltage, preamp
Old 19th November 2017, 03:55 PM   #21
CharlieLaub is offline CharlieLaub  United States
I was thinking of trying a single stage with the LTC6090 on an SOIC-->DIP adapter, using PCBs from this project of mine:
4-channel gain stage with power supply
If I could find a dual amp in a DIP-8 package that could handle at least +/- 22V rails I would try that, too.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 19th November 2017, 03:57 PM   #22
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Have some fun: apply the bandwidth-risetime equivalency principle (link to Wikipedia)
op-amp based, high-gain, high rail voltage, preamp-wikipedia_eq-png
to the LTSPICE plots in post #21. Risetime from the transient analysis plot, and bandwidth from the AC analysis plot. This circuit's closed loop gain, in decibels, is
  • Av,cl = 20 * log10(R3/(R1+R2)) = +30.6 dB
_
Old 19th November 2017, 04:04 PM   #23
DPH is offline DPH  United States
LME49860? It's just a LME49720 binned for 44 V between the rails vs 36 V. Heck you could just try a few DIP 49720's and see if they pass muster. (the 860 and 720 are literally the same silicon)
Happy DIYing, Daniel
Old 19th November 2017, 04:41 PM   #24
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Much easier to read, thanks. LME49710 is nice driver - you will need dual PSU now at two different rails.
Here is 90vpp design I just came up with. Still 5 transistors and now 0.0076% THD for 90vpp into 10k.
AKSA's Lender Preamp with 40Vpp Output-aksa-lender-preamp-hv-v2-1-90vpp-10kohms-fft-jpg
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 19th November 2017, 04:49 PM   #25
And a bit slower but still looks like it'd be more than functional in this application: ADA4522 (55V rail-to-rail) or ADA4700. But I'd be greedy and try to build a composite (admitting that their low bandwidth complicates the matter). Looking up, basically BesPav hits that one fairly well.
Or, heck, given the 20 dB gain gives you some phase margin budget, a bootstrapped front end opamp and a discrete PP class A output buffer on the back end (or grab something from Jim William's compendium of good ideas).
Old 19th November 2017, 04:54 PM   #26
If I can live with 44V Vs,max there is the OPA275 in a PDIP-8 package:
OP275 Datasheet and Product Info | Analog Devices
Ah, yea, the LME49860 on +/-22V looks like a winner and has a higher GBP. I would need to put it on an SOIC to PDIP adapter.
The ADA4522-2 is a bit GBP limited, like the OPA275, but can operate at +/-27.5V giving a little more headroom. Since none of these are rail-to-rail, you have to keep in mind where it will clip WRT the rail voltage.
Since my gain stage board has 4-channels I can run the gain through two stages and still accommodate two separate channels. All of the ICs must operate from the same supplies, however, so no 2-stage high/low Vs arrangement is possible.
Old 19th November 2017, 05:13 PM   #27
00940 is offline 00940  Belgium
00940's Avatar
opa275 : about 41.6vp-p on 44v
opa604: 42vp-p on 48v (the dual pdip version is still around but expensive)
lme49860: 42vp-p on 44v
The lme has clearly better specs though. The opa604 has the advantage of being a jfet input one, which can come in handy.
All that is excessive is insignificant. Talleyrand
Old 19th November 2017, 06:24 PM   #28
BesPav is offline BesPav  Russian Federation
Complicated correction, SR mostly defined by LTC6090’s output stage.
You’re welcome!
No, just 2x zener+cap+resistors for +-15 Volts from +-70 V rails.
Jfet input with a such low-resistance source (2 kOhm at inverting input) aren’t advantage. Just simulate noise.
Old 25th November 2017, 08:44 AM   #29
mchambin is offline mchambin  France
For a 44V op amp.
Let us not forget the old good NE5534.
Pretty good audio performances.
Transistor junction temperature is not transistor case temperature.
Old 25th November 2017, 03:10 PM   #30
Have some fun: apply the bandwidth-risetime equivalency principle to the LTSPICE plots in post [#20]. Risetime from the transient analysis plot, and bandwidth from the AC analysis plot.
Bandwidth at the closed loop gain is 250 kHz by eyeball (red intersection)
10% - 90% risetime is 2 usec by eyeball (white abscissa).
BW * RT product is 0.5, pretty close to theoretical prediction (0.34)
_
op-amp based, high-gain, high rail voltage, preampHide this!Advertise here!
JLHD 750Watts - high rail voltage nonprof Car Audio 5 22nd October 2015 01:27 AM
power supply rail voltage too high vintess Power Supplies 17 27th July 2015 09:56 AM
Cheap high voltage high wattage dual rail SMPS devices minimelkav Power Supplies 2 22nd August 2014 03:35 PM
high rail voltage chip amps? mbates14 Solid State 15 30th November 2012 02:48 PM
High voltage High gain OP AMP ? Cuda Solid State 9 15th September 2009 09:59 PM
