AKSA's Lender Preamp with 40Vpp Output
Old 14th November 2017, 08:55 PM   #81
AKSA is offline AKSA  Australia
Bogdan,
It was my opinion that I passed to X, and he saw no reason to disagree.
As has he mentioned, mosfets do not make good VAS in common source.
I don't believe this is incorrect, and is based from my personal experience, in particular, in the FetZilla, where a bipolar VAS is far superior to a ZVN, specifically in imaging. No reference to using common source output devices, although I don't that role much either.
Somewhat aggressive point you make. Why criticise X when he is on a roll, doing so much good work for the forum?
HD
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 14th November 2017, 09:32 PM   #82
JPS64 is offline JPS64  Germany
Mofo PCB arrives tomorrow and I need preamplifier (B1 KORG work on progress).
Schematics attached. I know, xrk971 would prefer SMPS + BOOSTER + CRCRC.
My idea, 3x SMPS + CLC: 2x 24VDC@>4A for Mofo left/right and 1x 48VDC for AKSA/LENDER preamplifier.
Not ordered yet, comments welcome.
Final design (EAGLE binaries, Gerber and all manufacturing datas) will be available for DIY.
JP
Old 14th November 2017, 09:41 PM   #83
xrk971 is offline xrk971  United States
xrk971's Avatar
Originally Posted by maty tinman View Post
Yesterday I heard your fourteen amplifiers and I loved the F5 Juma sound.
Virtual Audition of Very Simple Quasi MOSFET Amp
Maybe the 15th would be the Cubie3
That's a nice amp, I agree. Perhaps it's liberated from the confines of a 2d flat PCB that makes it sing? Certainly, Juma designs some very nice amps.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 14th November 2017, 09:52 PM   #84
xrk971's Avatar
JP
Looks very good JP, it's the MoFo arrival that drove the rapid layout of this preamp. Couple of comments. On CLC, I have found adding a moderate value parallel resistor like 51ohms helpful to prevent that LC from oscillating. The output bypass caps should be film, it looks like you may have MLCC and that's not good as it has high distortion. I have not simulated with DN2540 yet so not sure what the values will be.
Old 14th November 2017, 10:32 PM   #85
bogdan_borko is offline bogdan_borko  Serbia
bogdan_borko's Avatar
I wasn't criticising him, he was generalizing. I'm listening to a amplifier with mosfet vas, i tried bjt, but mosfet sounds better. In some sense it' simmilar to fetzilla... it's up to concrete aplication and a amplifier as a whole.Why didn't you use output mosfets in old aksa amps and use output bjts in new naksa amps? It is generalisation,period.
Svakog dana u svakom pogledu sve manje nazadujem.
Old 14th November 2017, 11:25 PM   #86
Originally Posted by xrk971 View Post
My mistake, I have built Juma's F5 which did not use ZTX BJT and went straight from JFET to MOSFET gate. If original F5 uses the BJT for VAS then that is good and agrees with what I said about not using a MOSFET as a VAS. But I am no F5 expert so leave it at that.
Yes, original F5 uses bjt for vas, Juma ruined it with his mosfets
Old 14th November 2017, 11:34 PM   #87
@xrk971 Thanks for comments: output bypass is VISHAY/ROEDERSTEIN MKC1860 (very cheap at pollin.de).
JP
Old 14th November 2017, 11:44 PM   #88
Max Headroom is offline Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
Originally Posted by AKSA View Post
......mosfets do not make good VAS in common source.
HD
Any ideas of why this is...the THD is not particularly different ?.
Dan.
Old 15th November 2017, 02:17 AM   #89
Bigun is offline Bigun  Canada
Bigun's Avatar
In my very limited experience with Class AB amps the sound is especially sensitive to the VAS and what happens there (typically compensation but the VAS is often at a key juncture between the Class A input stage/error amp and the non-linear impedance of the output stage). It's waaay more than the THD can explain. The detailed nature of non-linear capacitances and operating curves are all important.
Low OLG amps can also be sensitive to the design of the error amplifier - LTPs work best with high OLG if you want to avoid large differential signals sweeping the LTP gain curve into non-linear regions.
Of course, for comparable OLG you need a high current through a FET VAS if you want to match the transconductance of a bjt... and a bjt wrapped up in Cdom is already quite linear.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 15th November 2017, 02:35 AM   #90
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I'm also curious about this. My first guess is that it might have something to do with MOSFETs having much higher 1/f noise than bipolars. So low frequency details get lost, ISTM low freqs are very important to getting good soundstage depth.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
AKSA's Lender Preamp with 40Vpp OutputHide this!Advertise here!
FS: AKSA GK-1 (EL) Preamp kit kv2 Swap Meet 1 14th April 2017 12:04 PM
Alternative output transistors for the Baby AKSA 55 cs Solid State 10 13th September 2013 11:06 AM
preamp for aksa 55 Professor smith AKSA 98 12th February 2012 01:11 AM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 01:52 PM
Aksa preamp? rick57 Solid State 11 19th May 2006 10:26 PM
