AKSA's Lender Preamp with 40Vpp Output
Old Yesterday, 03:58 PM   #781
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Check polarity of the inputs/outputs from 8pins connector to your amp. One row is GND and othe row is signal. If you drive signal input to GND the sound will be very soft. Likewise if you drive outputs with GND from Preamp sound is very soft.
Your bias seems ok and gain of 10x should be plenty loud.
One way to check if Preamp is working stand-alone is to connect cheap $1 earbud headphones (free from airlines) to outputs of the Preamp. Polarity won’t matter as its isolated and if it plays loudly, Preamp is good.
XRKaudio https://www.etsy.com/shop/XRKAudio
AKSA's Lender Preamp with 40Vpp OutputHide this!Advertise here!
FS: AKSA GK-1 (EL) Preamp kit kv2 Swap Meet 1 14th April 2017 11:04 AM
Alternative output transistors for the Baby AKSA 55 cs Solid State 10 13th September 2013 10:06 AM
preamp for aksa 55 Professor smith AKSA 98 12th February 2012 12:11 AM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 12:52 PM
Aksa preamp? rick57 Solid State 11 19th May 2006 09:26 PM
