AKSA's Lender Preamp with 40Vpp Output
Old 12th July 2018, 06:03 PM   #701
JPS64 is offline JPS64  Germany
I buy this high quality RCA at Audiophonics in France. You find them also at Hifi Collective in UK. Some chinese shops also.
For me best interconnexions are very important. I‘ve an IFI dac and after 2 month I replace defectuous RCA!
JP
Old 12th July 2018, 06:35 PM   #702
pcgab is online now pcgab  United States
I got mine from HifiCollective. They're not cheap, but not that expensive, all things considered.
Low cost high quality straight gold plated RCA sockets | Hifi Collective
Old 12th July 2018, 07:49 PM   #703
jwjarch is offline jwjarch  United States
jwjarch's Avatar
I took a chance on these and they are actually great quality. I would even go so far as to say they are the same as the HiFi Collective jacks, but at the Chinese wholsale price. And, yes, the pins can be reconfigured for the vertical mounting that the AKSA Lender PCB requires. Just be careful with the plastic.
Taiwan-made gold-plated RCA turntable DAC decoder digital coaxial PCB board sock
Note: the picture shows 2 jacks but the price is only for 1. Still a better deal than HiFi Collective though.
Old 12th July 2018, 08:57 PM   #704
Skylar88 is offline Skylar88  South Africa
Thanks for the recommendation, jwjarch. It really does look like good quality. My only concern is that it lacks a second nut to adjust the mounting height. But that shouldn't be an insurmountable problem.
Old 12th July 2018, 10:22 PM   #705
jwjarch's Avatar
You're welcome Skylar. Another note, however. I've found the mounting nuts are irrelevant when using the PCB since the jacks are mounted too close together to screw the nuts on. If you look at JPS64's build I noticed it doesn't look like he's using the nuts either.
Old 13th July 2018, 12:52 AM   #706
I see what you mean. Thanks for pointing that out. Isn't it important then to not have to right-angle version? It seems the two extra pins are required for mounting it solidly to the PCB if the nuts are not going to be used.
Old 13th July 2018, 03:13 AM   #707
jwjarch's Avatar
The right angle version is 100% convertible. If you’re careful you can take the Two mounting pins out with a needle nose pliers and put them back in the bottom of the jack. The holes are already there. That’s what I did on mine.
Old 13th July 2018, 06:06 AM   #708
Good to know. Thanks for that.
Old 13th July 2018, 04:59 PM   #709
THT boards equipped.
JP
Old 13th July 2018, 05:28 PM   #710
Carl_Huff is offline Carl_Huff  United States
Here is my take on this project. I haven't fabbed any PCBs as of yet and I really need to check the layout for errors one more time.
The IO is on another PCB. I have multiple 'standard' versions that I select from dependent upon the project.
Best Regards,
Carl Huff
AKSA's Lender Preamp with 40Vpp OutputHide this!Advertise here!
FS: AKSA GK-1 (EL) Preamp kit kv2 Swap Meet 1 14th April 2017 11:04 AM
Alternative output transistors for the Baby AKSA 55 cs Solid State 10 13th September 2013 10:06 AM
preamp for aksa 55 Professor smith AKSA 98 12th February 2012 12:11 AM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 12:52 PM
Aksa preamp? rick57 Solid State 11 19th May 2006 09:26 PM
