AKSA's Lender Preamp with 40Vpp Output
Old 18th January 2018, 01:49 AM   #451
drpro is offline drpro  United States
My boards arrived today. Thank you X.
Question, from my reading the daughter boards let you set the gain. I ordered an extra set of DB, so I hope I read right. Looking for one set with 4v p-p and the other 20v p-p. In my reading haven't discovered what values, guessing here of resistors for setting the different outputs.
Tnx
David
Old 18th January 2018, 04:38 AM   #452
ammel68 is offline ammel68  United States
Sin Bin
Originally Posted by xrk971 View Post
Do yourself a favor and get these headband magnifiers. I am knocking on 50 as well and eyesight is not what it used to be either. Even for TH soldering, I wear them half the time. I have used them for 5 years - same basic $7 model (nowadays $9). Also, you will need a good pair of stainless steel tweezers, preferably Swiss made and about $25, a smaller solder iron tip (but I like to use solder paste from a syringe and a hotplate).
SE MH1047L Illuminated Multi-Power LED Head Magnifier - Magnifying Glass - Amazon.com
But, like I said, this Aksa Lender pre is available as all TH construction. Btw, the main board is a healthy 135mm x 114mm.
So I have the M3 as well, and am comparing them now. You will not regret making the Aksa Lender - it sounds better, is quieter, can get way more voltage swing and not go nuts with distortion.
Thank you for the suggestions, X!
I've got to try to Hugh's Lender. If it kicks the Magni 3's a$$ in SQ as a preamp, then color me impressed.
Old 18th January 2018, 06:56 AM   #453
xrk971 is offline xrk971  United States
xrk971's Avatar
Just cased it up now I can take it with me to work
Aksa Lender HPA-aksa-lender-hpa-amp-01-jpg
Aksa Lender HPA-aksa-lender-hpa-amp-02-jpg
Aksa Lender HPA-aksa-lender-hpa-amp-03-jpg
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 18th January 2018, 09:02 AM   #454
robert1325 is offline robert1325  Netherlands
Would this pre work well in front of a class d amp like the new tpa32xxevm boards? I wouldn't need much gain.
Old 18th January 2018, 02:07 PM   #455
xrk971's Avatar
Well, it works well in front of any power amp IMO as it is essentially a noise-free way to get volume control and provide a constant impedance to the ampís input stage to make sure bass extension is a deep as it can be. On ultra low ppm levels of distortion amps, it will give a slight SE Class A harmonic signature.
I use a Pocket Class A as a preamp for the TPA3116D2 and that works very well.
Old 18th January 2018, 02:10 PM   #456
xrk971's Avatar
Be sure to check out GB thread - tips on stuffing TH:
Old 20th January 2018, 09:11 PM   #457
xrk971's Avatar
Congrats to Vunce who got his up and running! Beautiful work!
Old 29th January 2018, 04:14 AM   #458
xrk971's Avatar
The new ALPHA amp thread is here:
Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Sneak preview of performance:
Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier-alpha-1-19amp-2-83vrms-8ohms-fft-jpg
Old 2nd February 2018, 05:59 AM   #459
xrk971's Avatar
I forgot to mention to folks following this thread, in case you haven't seen it yet, there is a nice Class A amp based on this front end that Hugh came up with called the ALPHA (Aksa Lender P-mos Hybrid Aleph). The thread is here:
Here is the PCB layout by JPS64:
FFT for 2.83vrms into 8ohms with 1.2amps bias:
Old 3rd February 2018, 01:15 AM   #460
GnuB is offline GnuB  United States
GnuB's Avatar
Thanks X, boards arrived today. :-)
AKSA's Lender Preamp with 40Vpp OutputHide this!Advertise here!
FS: AKSA GK-1 (EL) Preamp kit kv2 Swap Meet 1 14th April 2017 12:04 PM
Alternative output transistors for the Baby AKSA 55 cs Solid State 10 13th September 2013 11:06 AM
preamp for aksa 55 Professor smith AKSA 98 12th February 2012 01:11 AM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 01:52 PM
Aksa preamp? rick57 Solid State 11 19th May 2006 10:26 PM
