AKSA's Lender Preamp with 40Vpp Output
Old 1st January 2018, 10:14 PM   #401
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Hi Nico,
Thanks, but all the credit for layout goes to JPS64. He does this for a living - so these are perhaps, some of the most professional looking layouts that I have ever seen. The ground planes on the MB are insanely good.
For example, the multiple ground planes follow a star topology with the hub at the main input/output connector. The left and right are separate. The CRC and Cap mx ground planes are separate, etc.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 2nd January 2018, 07:16 AM   #402
Got Foam?
xrk971's Avatar
Latest test results with MELF SMT board looks pretty good.
4Vpp into 7kohms (45v Vcc):
AKSA's Lender Preamp with 40Vpp Ouput GB-aksa-lender-pre-melf-4vpp-7kohm-fft-png
20Vpp into 7kohms (45v Vcc):
AKSA's Lender Preamp with 40Vpp Ouput GB-aksa-lender-pre-melf-20vpp-7kohm-fft-rt-png
Now, for the thread title namesake, 40Vpp into 7kohms (50v Vcc):
AKSA's Lender Preamp with 40Vpp Ouput GB-aksa-lender-pre-melf-40vpp-7kohm-fft-50vcc-png
And if one raises Vcc to 59v, just before clipping this preamp can drive 51Vpp into 7kohms with 0.013% THD:
AKSA's Lender Preamp with 40Vpp Ouput GB-aksa-lender-pre-melf-51-4vpp-7kohm-fft-59vcc-png
That's good for about 41Wrms into 8ohms if the power amp can handle it.
With Vcc at 59v, the SMT board is a bit hotter - but not excessive. I will let it burn in overnight to see if it can take it long term.
Old 3rd January 2018, 12:50 AM   #403
e_fortier is online now e_fortier  Canada
e_fortier's Avatar
Hi X
Very good work.
For the +48V power supply would this be ok ?
Same as the one in Millett starving student HA;
CISCO 48V 0.38A AC/DC Adapter Desktop Power Supply PSU 34-2477-01 EADP-18FB B | eBay
Eric
Old 3rd January 2018, 02:56 AM   #404
Got Foam?
xrk971's Avatar
Originally Posted by e_fortier View Post
Hi X
Very good work.
Eric
I have not tried this but it may work fine. I personally like variable DC step up so you can set your Vcc precisely. With this you will be limited to 44v Vcc after cap Mx.
Old 6th January 2018, 06:18 AM   #405
jwjarch is offline jwjarch  United States
jwjarch's Avatar
Originally Posted by gtose View Post
I linked to them on eBay in my previous post: AKSA's Lender Preamp with 40Vpp Output.
Took a chance on the $2.66 rca connectors. They can be converted if you are careful. The plastic part of the connector is fairly brittle. Don't ask me how I know. Even so I think I'll go with these for my build. They are really good quality for the money.
Old 6th January 2018, 05:18 PM   #406
Got Foam?
xrk971's Avatar
You actually have them in-hand and we’re able to convert them?
Old 6th January 2018, 10:13 PM   #407
jwjarch's Avatar
Yes Sir! The large pins pull out of the body with a needle nose pliers and the signal wires bend relatively easy. The trick is putting the large pins back in on the bottom without cracking the plastic body.
Old 7th January 2018, 06:08 AM   #408
Harry3 is offline Harry3  Australia
Default C1
What are your thoughts in using one of these caps (Bipolar, 50V, Dia=10mm) from Mouser for C1?
647-UVP1H101MPD
667-ECE-A1HN101U
Old 7th January 2018, 08:48 AM   #409
Got Foam?
xrk971's Avatar
That’s probably fine Harry3. But there may be a thing as too much capacitance. I installed my favorite 10uF Elna Silmic II there bypassed with 2.2uF 250v film. The FFT had elevated 20dB above -130dB noise floor of infrasonic (sub 40Hz to DC) content. I removed 10uF and infrasonic noise went away. Although +20dB above -130dB is pretty inaudible, it probably means home theater content would be fully represented through this preamp. The F3 with 2.2uF C1 is about 2Hz so even 2 octaves above is 8Hz should be plenty of bass extension. I recommend using at least a film cap there and skip the electrolytic if given a choice.
Old 7th January 2018, 09:20 AM   #410
Hi X,
I am referring to the capacitor that is in series with a 1K (R11) resistor on the daughter board.
I think you are referring to the input cap C132 on the mother board.
The information that you sent is good.
regards
Harry
AKSA's Lender Preamp with 40Vpp OutputHide this!Advertise here!
FS: AKSA GK-1 (EL) Preamp kit kv2 Swap Meet 1 14th April 2017 11:04 AM
Alternative output transistors for the Baby AKSA 55 cs Solid State 10 13th September 2013 10:06 AM
preamp for aksa 55 Professor smith AKSA 98 12th February 2012 12:11 AM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 12:52 PM
Aksa preamp? rick57 Solid State 11 19th May 2006 09:26 PM
