AKSA's Lender Preamp with 40Vpp Output
Old 9th November 2017, 07:57 AM   #11
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Beutiful result!
Can someone explain why we choose P devices in the IPS?
I asked same question 3 days ago under the link below where a similar schematics was presented by Zen Mod (~4 posts above mine), but no answer yet.
About possible Babelfish J interest
Old 9th November 2017, 08:04 AM   #12
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
So the output is 7mW, what will you do with that?
Kindest regards
Nico
Old 9th November 2017, 08:22 AM   #13
AKSA is offline AKSA  Australia
Output is low impedance (<5R), but limited to 12mA CCS. This can nicely drive a small output stage, single ended or PP. The buffer, Q4, could be made a FET or even increase current to 30mA. That would boogie!
UT, if you use pnp for the LTP, it mandates npn VAS, and my experience is that npn VAS has lower parasitics and greater GBW than pnp in the same role.
HD
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 9th November 2017, 11:42 AM   #14
Samuel Jayaraj is offline Samuel Jayaraj  India
Also generally PNP in LTP gives lower current noise, doesn't it? Reason why a lot of phono preamps were designed that way. Not sure if it matters here with signal levels involved. Ofcourse, as Hugh said, it also allows for NPN VAS which is just what you want for its desired characteristics.
Sam
Old 9th November 2017, 12:01 PM   #15
PMA is offline PMA  Europe
PMA's Avatar
I do not think it would be audible, but why is there that ninth of some 0.002%?? The 9th is usually 110 - 130 dB below the fundamental. Just curious where it is created.
Old 9th November 2017, 01:14 PM   #16
juma is offline juma  Germany
juma's Avatar
Originally Posted by PMA View Post
...why is there that ninth ...
Yes, and the 5th is way too high - maybe some measuring setup artifact ?
Using PNP LTP in single rail PSU circuit is good for the PSRR too.
Anyway I'd lose Q4 and unstrangle Q3, let the LTP breathe, change CCS and at least bootstrap the tail of of the LTP. Gain should be higher so that weaker sources and/or quieter recordings can bring enough voltage swing at the output. Drive capability should stay about the same.
Roughly, something like this (R1/R2 divider might need some adjusting to ensure symmetrical clipping and freq.compensation should be checked in vivo. Practical details like PSU bypassing and similar are logical addition) :
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Old 9th November 2017, 01:29 PM   #17
xrk971 is offline xrk971  United States
xrk971's Avatar
I'm wondering where the 5th and 9th are from too as not in sim. I should change audio interface and PC to see if it clears up.
Juma, thank you for the suggested schematic. I don't believe it is the same topology anymore though. Have you simulated it yet? Looks interesting. It could be a headphone amp with a larger C2 and higher bias, as could Aksa' circuit.
AKSA's Lender Preamp with 40Vpp Output-lemo-gif
...if you use pnp for the LTP, it mandates npn VAS, and my experience is that npn VAS has lower parasitics and greater GBW than pnp in the same role.
This now seems perfectly clear and a great reason. I have wondered myself.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 9th November 2017, 01:47 PM   #18
juma's Avatar
Originally Posted by xrk971 View Post
... Have you simulated it yet? ...
Sorry but no, I only built it. Yes, I know that these days simulation is more valuable than the real build but I'm an old-fashioned guy...
Actually, that sch. is part of the power amp I made some time ago (imagine one pair of Lateral MOSFETs added at the output, with one LED between the Gates to bias them).
Old 9th November 2017, 03:25 PM   #19
Bigun is offline Bigun  Canada
Bigun's Avatar
I looked at a similar topology many years ago but never built it (yet) TGM4 amplifier
However, what is shown in post#1 is not quite the Lender circuit. The original circuit, 'invented' by Rudolph Lender when he was at Motorola uses a different arrangement with two transistors. I do remember asking Hugh about it too...
Originally Posted by AKSA View Post
Gareth,
Tried the Lender, simulated it also. No OLG advantage over a single ended drive to a stock common emitter VAS, and no discernible advantage sonically. However, it does combine some elements of CM, tending to force current balance in the LTP by adjusting VAS current. But this may not be very useful if the VAS current is fixed anyways, as it normally is.
Hugh
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 9th November 2017, 03:33 PM   #20
xrk971's Avatar
Originally Posted by Bigun View Post
I looked at a similar topology many years ago but never built it (yet)...
Agreed, hence which is why I said "inspired by" Lender. Nice amp design the TGM4, what does TGM stand for?
AKSA's Lender Preamp with 40Vpp OutputHide this!Advertise here!
FS: AKSA GK-1 (EL) Preamp kit kv2 Swap Meet 1 14th April 2017 12:04 PM
Alternative output transistors for the Baby AKSA 55 cs Solid State 10 13th September 2013 11:06 AM
preamp for aksa 55 Professor smith AKSA 98 12th February 2012 01:11 AM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 01:52 PM
Aksa preamp? rick57 Solid State 11 19th May 2006 10:26 PM
