PGA2310 preamp turn on mute
Old 9th November 2017, 08:00 PM   #21
anatech is offline anatech  Canada
anatech's Avatar
Hi belyakove,
Maybe my question is stupid but if output would be left just unconnected why would that affect output capacitor charge?
You want the capacitor to be in whatever state it is normally in when you release the mute or you will get some noise for certain. When the output is connected, if there is a voltage on the other side of a coupling capacitor, it has to charge. If it charges when the mute is released, the impulse from charging is the same as an input signal.
When might this happen? On an amplifier input that has a BJT diff pair. Typically there will be from 50 mV to 300 mV DC voltage. Therefore the capacitor has to charge. If one end floats, it cannot charge until you connect the buffer. The charge current has to go somewhere, and a 10 K resistor will offer some path to charge that capacitor. If the capacitor is charged when you release mute, little to no noise will result.
Now you should understand why the mute takes so long to release.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 9th November 2017, 08:27 PM   #22
belyakove is offline belyakove  Netherlands
Originally Posted by russc View Post
Check easy stuff like: do you still get thump with pre-amp inputs shorted to ground?
Do you have any DC offset at output? Have you a buffer on the output and this is causing thump?
According to data sheet, gain is at zero on power up until volume setting is sent by processor.
So activating mute on power up does nothing.
My PGA2320 pre-amp signals power amps on from standby (5v trigger from Arduino pin) and no thumps.
I don't have buffer on output so the PGA is the last stage on the chain. I just tried to set gain of PGA to always 0 and hardly wire MUTE pin to active on my breadboard but power on thump is still present. So it seems that problem cannot be solved without external mute circuit.
Maybe 2320 behaves differently than 2310. However datasheet for these two says the same (unlike 2311)
Old 10th November 2017, 05:12 AM   #23
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by belyakove View Post
....Mute transistors are connected with emitter to signal and with collector to ground......
Correct.
Early transistors, C and E were interchangeable. They are both just junctions to B.
Modern transistors are optimized for high amplification at E and high breakdown voltage at C.
They sure can be used in reverse. Typically reverse hFE is not 100+ but about 1. Poor amplifier. But the mute is not an amplifier. The control signal current can easily be much larger than the signal current. It has been a while since I knew this, but reverse connection does have advantages in this odd application.
The problem here is that the "off" E-B junction will break-down at 7 Volts!! This is not a problem for 0.5V-2V cassette decks and similar home hi-fi interconnects. It CAN be a problem if you are running studio levels as implied by this chip and its +/-15V nominal supplies. You are giving-up half your headroom.
I can't believe the PGA part thumps. They were used in large quantities in consoles for fussy users. I'd be looking for stray DC being muted.
Old 10th November 2017, 06:24 AM   #24
I think I tried everything now. I just tried to disconnect PGA's inputs from buffer and connect them to the ground. Zero crossing enabled, MUTE active, gain set by controller to 0. And still have a pop on turn on. Also I tried to connect output via 100 uF electrolytic so all dc should be eliminated. Don't know what else I can try to make it even more silent.
I also found this discussion on TI's forum where TI's employee checked this behaviour on PGA2310 evaluation board. There are measurements from oscilloscope it that thread that show this click during ramp up.
Old 10th November 2017, 06:28 AM   #25
OlegSh is offline OlegSh
Can you post schematic of what you built? It seems that we miss some important detail here.
Old 10th November 2017, 06:51 AM   #26
Here are the schematics of single channel of my build. The second one is the same. AGND and DGND is completely separate connected only at power supply level. I've marked where ground is digital, where not market it's analog.
Old 20th November 2017, 09:30 PM   #27
Tried today with a Panasonic photomos relay AQW212EH. I used it to ground the output of preamp and the thump is gone, that's a good thing. Seems that it is a solution that will work. The only question that I have is whether such thing as photomos relay can add some distortion?
Also wanted to try with reed relay but accidentally ordered 12v piece instead of 5v.
Old 20th November 2017, 11:17 PM   #28
anatech's Avatar
Hi belyakove,
By definition, the relays cannot create distortion in the signal as the outputs are shorted to ground anytime signal current does flow through the relay.
-Chris
Old 21st November 2017, 05:50 AM   #29
Fast Eddie D is offline Fast Eddie D  United States
I used a telecom relay to short the output on my latest preamp. Silent startup, very small "thump" on shutdown. Relay stays shorted for 2.5 seconds on startup. Everything is controlled by a 555 timer chip.
Very simple with no fancy parts. I'm quite satisfied and will use this control circuit again.
Old 21st November 2017, 10:14 PM   #30
Originally Posted by anatech View Post
Hi belyakove,
-Chris
I understand that But I mean in case when relay is turned off and mosfets are closed. In this case there's still closed mosfet sitting on the signal line. Datasheet for this relay states 1 uA of leakage current.
PGA2310 preamp turn on muteHide this!Advertise here!
Arduino controled PGA2310 Preamp ialpha Analog Line Level 34 10th August 2016 02:41 PM
PGA2310 PreAmp for TA2024 board nelson_mendes Analog Line Level 3 25th November 2015 05:33 PM
The filtering of the preamp with the PGA2310 project dean863249 Solid State 10 19th January 2015 10:16 AM
PGA2310 based preamp+ remote vinodt1347 Analog Line Level 3 8th June 2012 09:28 PM
APEX PA Amp Turn on off mute - need design support against obsolet devices NMOS Solid State 0 26th August 2011 03:01 PM
