How do i create second harmonic distortion?
Old 5th November 2017, 06:46 PM   #21
Bigun is offline Bigun  Canada
Bigun's Avatar
I don't like op-amps because there's no fun in 'em. A passive option is to use a small transformer and add some dc-bias current through it to control where the signal sits on the BH curve - voila, adjustable 2nd harmonic distortion.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 5th November 2017, 06:46 PM   #22
PMA is offline PMA  Europe
PMA's Avatar
I am using Keith Howard's adddistortion
Freeware
Old 5th November 2017, 06:47 PM   #23
Mooly's Avatar
Originally Posted by filthyone View Post
I tried in audacity, i couldn't find that specific "distortion" plugin, but i tried "diode processor" using half wave settings. To my ears, at low levels the distortion is not that bad, it's kind of bearable. At higher levels it just sounds distorted, and at full wave settings it is just unbearable.
I alse tried "harmonic generator" with similar results. Odd order harmonics just sound harsh and evil, even order harmonics are more bearable (especially low order, the higher you go in order, the worse it gets) but still sound distorted/bad.
I'm already wondering, who and why would prefer a slightly distorted signal over a nice and clean one? (except maybe guitar players)
Its installed by default although I am running the latest version after clean installing W10
Old 5th November 2017, 07:44 PM   #24
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Is there a circuit that adds a nearly constant proportion of 2nd harmonic?
Supposedly a pure square-law device would do that (I think). But what would be the point, no audio amplifier acts like that? Their "percent distortion" as found in data sheets or ad literature is typically just some arbitrary % value they chose to define their "rated power" at. At low levels the distortion is very, very much lower. You can't practically find out what "playing at 5% distortion sounds like" (for total harmonic or any specific order) because with hifi amps that only happens at peaks of sinewaves, so it is more or less an undefined condition with music.
Badly designed class AB or B amps that have crossover distortion being the exception of course. With those % distortion can go up at lower levels. Those are pretty much extinct any more though.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 5th November 2017, 07:55 PM   #25
Pano is offline Pano  United States
Pano's Avatar
Where's Wavebourne? . He built a distortion adder years ago and found that no one liked it their system.
I'm not too sure about this Euphonic/Euphoric distortion so many posters claim that "those people" like.
Take the Speaker Voltage Test!
Old 5th November 2017, 09:02 PM   #26
Bigun's Avatar
I added distortion to a couple of my amps, didn't like it either so took it out. It was a big surprise for me that I actually like high feedback low distortion amps ! But for some music, a SET amp does wonders. Go figure.
Old 5th November 2017, 09:05 PM   #27
PMA's Avatar
Euphonic distortion is a nonsense, however it sometimes happens that people prefer a more distorted music file to original file in a blind test.
Old 5th November 2017, 09:06 PM   #28
MarcelvdG is online now MarcelvdG  Netherlands
No-one seems to have mentioned the word translinear yet.
Taking advantage of the exponential characteristics of bipolar transistors and using loops of transistor BE-junctions, you can make just about any non-linear function you want to make. This is known as the translinear principle, and it was invented by Barrie Gilbert.
For example, the attached schematics should produce an x^1.5 type of distortion, just like the voltage to current characteristics of valves do according to Child's law (which no valve follows accurately, though). Mind you, I haven't tried either of these schematics. The left and right stacks of transistors must have equal numbers out of IC1 and equal numbers out of IC2. The CA3046 can be replaced with an LM3046, which is still available although it is also going out of production.
When you leave out Q2 and Q6 (and reduce R4 to 6.8 kohm in the 9 V version), it becomes a second-order distorting circuit. You then only need one LM3046 per channel.
R1A and R1B are supposed to be ganged potmeters. They are used for setting the level of distortion.
Old 5th November 2017, 09:07 PM   #29
PMA's Avatar
They do not in case you listen to complex classical orchestral music. They smear philharmonic music.
Old 5th November 2017, 09:12 PM   #30
PMA's Avatar
It reminds me my diploma thesis almost 40 years ago, part of which was a multi-function converter with two LOG and two EXP amplifiers (BJT in opamp feedback). It was possible to wire it for pure quadratic transfer function.
How do i create second harmonic distortion?Hide this!Advertise here!
Harmonic Distortion Profiles MagicBox Solid State 3 16th May 2013 07:48 PM
harmonic distortion vitalstates Tubes / Valves 13 15th June 2010 08:17 PM
Why is distortion harmonic? dsavitsk Tubes / Valves 48 12th March 2008 02:49 AM
second harmonic distortion tenderland Tubes / Valves 5 5th August 2004 11:29 AM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
