How To Make Passive High Pass Filter?
Old 31st October 2017, 12:20 PM   #22
DEAFASABAT is offline DEAFASABAT  United States
Originally Posted by cacao ambiance View Post
oow goodie help already!
was hoping for something generic that i can swap between amps.
I use tpa3116/8, irs2092,tpa3250, tas5611, tpa3255, tk2050. I mainly use the tpa3116 black board for these speakers. I have attached the 2 Input Impedance related pages from the datasheet for the tpa3116. next looks like i need to find out what gain resistors are used to know the Input Impedance, right?
next ill get photos of the speakers
If you do come up with a working passive high pass network, it could be interchangeable only if the amps' input impedances are all the same. Possible, not too likely. Better to have a tailored network for each amp you use. -daab-
Old 31st October 2017, 12:25 PM   #23
Originally Posted by ceulrich View Post
Hello cacao ambiance,
If I understand your question correctly, I had a similar issue a while ago. Due to room placement, my right speaker had a bit more low bass output than the left speaker, so I wanted to tame down the one with more output. My solution was to insert a capacitor between the output of my preamp and the input of the power amplifier for the right channel. I worked up a little spreadsheet to calculate the capacitance needed for the known input impedance of the power amplifier.
The first figure shows the simple schematic and the calculations for determining the -3dB frequency. The second figure calculates and plots the response curve.
In my case I used a pair of 0.1 MFD MusicCaps in series to get 0.05 MFD or 50 nF, which I thought was close enough to the calculated 47 nF for this application. This solution worked fine to tame the low bass output so the two speakers were better matched.
I hope this will be of some help.
ceulrich
So a first order, 6db/octave function did the trick? If so, it makes it fairly easy vs. implementing a second or higher order filter.
Old 31st October 2017, 12:35 PM   #24
Fast Eddie D wrote: "With passive you're pretty much stuck with 3 dB/octave. Otherwise go active."
Should be 6db/octave, using just one capacitor.
-daab-
Last edited by DEAFASABAT; 31st October 2017 at 12:35 PM. Reason: Loose nut behind keyboard
Old 31st October 2017, 05:16 PM   #25
Fast Eddie D is offline Fast Eddie D  United States
-daab-
Yes, you're correct. I'm thinking -3dB frequency.
And I was proven wrong anyway, with the link to second order passive filters.
Old 4th November 2017, 03:15 AM   #27
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by Fast Eddie D View Post
With passive you're pretty much stuck with ....
Aside from the 3/6 typo---
ANY order passive filter can be built.
With caps and coils, any filter function can be done.
With only R-C (no coils), high-order filters are pretty lame (instead of a corner they roll off very slow).
In audio, where coils are extravagant, active filters are miracle workers.
How To Make Passive High Pass Filter?Hide this!Advertise here!
Passive high pass filter to prevent excessive excursion SpartanX58 Subwoofers 5 3rd May 2017 10:08 PM
Passive high pass filter before Topping TP22 7V Class D 4 22nd October 2016 12:14 AM
Passive high pass filter app. 60 hz emosms Multi-Way 12 4th February 2016 12:27 PM
Passive line level low and high pass filter help Matttcattt Multi-Way 54 28th July 2015 08:46 PM
RL passive high pass line level filter noviygera Analog Line Level 11 9th March 2012 04:13 AM
