RC filter component selection
Old 9th November 2017, 11:49 AM   #61
Mark Whitney is online now Mark Whitney  Netherlands
Mark Whitney's Avatar
Originally Posted by robinlawrie View Post
for example if i added a 500nF capacitor in parallel with that 100pf one ( easier than swapping, its a 603 smt component) i should (if my studying has paid off) get a lowpass of 3.18khz there, instead of the current 15mhz one.
A problem with using 100 Ohm / 500nF is the low impedance at higher frequencies. This could be a problem for the opamp connected as the source.
Regards Mark.
Old 9th November 2017, 02:21 PM   #62
robinlawrie is offline robinlawrie  United Kingdom
Yeah i thought that might be the case.
I assume adding a resistor in series with the capacitor to raise impedance at the high frequencies, without affecting impedance at lower ones is a "thing" probably well known and with a name.
I assume it would reduce effectiveness of filter, and depend on ratio between resistor chosen, and input impedance of next stage of amp...?
Old 10th November 2017, 05:14 AM   #63
PRR is offline PRR  United States
PRR's Avatar
for example if i added a 500nF capacitor in parallel with that 100pf one......
I say try it.
Cap loading is not an issue here.
RC filter component selectionHide this!Advertise here!
Help with component selection. Spec Analog Line Level 11 21st March 2015 03:49 AM
Help with component selection for filter karha096 Analog Line Level 0 5th September 2013 07:40 PM
Class D output filter Design and component selection Amini Class D 5 21st November 2012 03:53 AM
Component selection eitanwaks Tubes / Valves 31 4th February 2006 06:27 AM
